Question about HP OfficeJet 7410 All-In-One InkJet Printer
Green on/off button not working. Just HP logo in display box disp
The on/off button isn't working. Green light does not come on. The HP logo is the only thing showing in the display box.
I called HP and they guided me thru a trouble shooting session. In the end, the tech thought I had a defective Power module. I have attempted to locate the part locally but find I can only order it online. Since I'm not positive this is the problem, I am reluctant to order the part.
Has anyone else had this problem?
    Sergeant:
  • 449 Answers
Open the printer and check the voltages at the power points. If they are present then power module is ok.
Posted on Jul 17, 2009
  • SmartAviator
    SmartAviator Jul 17, 2009
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
May 12, 2012 | Vizio M261VP 26" LCD TV
Tip
Resetting Low Tire Light (2003 Monte Carlo)
1. Turn the ignition to ACC or Run and turn off the radio.
2. Press an hold the TUNE DISP button on the radio for at least five seconds until SETTINGS is displayed.
3. Press the SEEK PSCAN up or down arrow to scroll through the main menu.
4. Scroll until TIRE MON appears in the display.
5. Press the 1PREV or 2 NEXT button to enter the submenu. RESET will be displayed.
6. Press the TUNE DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second.
7. Once the monitor has been reset, scroll until EXIT appears on the display.
8. Press the TUNE DISP button to exit programming. A chime will be heard to verify exit.
on Feb 27, 2012 | 2003 Chevrolet Monte Carlo
Low tire pressure light wont go out
The Low Tire Pressure Indicator must be reset using the Radio. This can only be performed if you have the factory radio installed in the vehicle. This vehicle does not come with an active tire pressure management system, and as such, this light must be reset manually.
1.) Turn Radio Off 2.) Hold down disp button for 10 seconds 3.) Setup Menu should display 4.) Scroll through menu to view "Tire Pressure" (use seek buttons) 5.) Select the Tire Pressure option (Press Radio Button 1) 6.) Reset should be displayed on screen (Press disp button) 7.) Tire Pressure Light should reset
Nov 29, 2010 | 2000 Chevrolet Impala
2001 Impala TPMS reset, radio and headlight options DONT WORK
CHEVY IMPALA &
MONTE CARLO
On a Chevy Impala or Monte Carlo with indirect TPMS, a totally different reset procedure is required. You can use the light switch or radio to reset the system. With the light switch procedure, turn the ignition on (engine off), the turn the light switch from OFF to parking lamps three times within five seconds. With the radio technique, turn the ignition on (engine off). With the radio off, hold the DISP button until “SETTINGS” is displayed. Use the SEEK button to scroll down the menu until you see “TIRE MON.” Press the PREV or NEXT buttons until “RESET” is displayed. Then press the DISP button again. You should hear a chime and see “DONE” to indicate the TPMS system has been successfully reset. Use the SEEK button to scroll through the menu until “DONE” is shown, then press DISP once more to exit from the learn mode.
Dec 24, 2009 | 2001 Chevrolet Impala
How to reset low pressure light after having new tires installed
Though all of these TPMS applications use a similar technology and strategy to detect a low tire, there is no common reset procedure. GM is probably the worst, with 10 different reset procedures depending on the application. Toyota is probably the best, with only one simple reset procedure for all of their indirect TPMS systems (though a slightly different procedure is used on the Lexus models).
TPMS reset procedures may also be found in the vehicle owner’s manual (if it hasn’t been lost). Open the glove box and check the index in the owner’s manual for any TPMS information.
CHEVY IMPALA &
MONTE CARLO
Good luck and this should work for you. They changed the reset procedure on the 2006 Impala.
Dec 08, 2009 | 2003 Chevrolet Impala
HP 7410 will not boot. It powers up and the HP logo screen flashe
This was solved really well on this blog. It is some problem with the wifi board. If you disconnect it (no so hard and well explained on the blog) you will have network printing over a cable but no wireless.
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
Oct 23, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 will not boot. It powers up and the HP logo appears on the screen with a progress bar. The display then scrambles and the power light flashes green. No buttons work or do anything.
connect the printer directly to the wall socket for the power supply if it is connected thrugh surge protector.
perform a reset :
unplug the power cable .
press and hold # and 6 key on the printer..
plug in the cable wait for 20 secs then release the buttons..
after this the printer will re-initialize .. this may take few mins..
and chek after that
Oct 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Pavilion Notebook Monitor display is green and have not been able to get back to blue . The computer is working but you can not see the icons, text, etc very well.
Try uninstalling the display driver from the Device Manager then restart the Computer. After restarting the Computer, reinstall the display driver.
Perform the steps given below to access the Device Manager:
(i) Please press the Windows logo on the Keyboard and then press the "R" key while holding down the Windows logo key to open the Run dialog box.
(ii) Then, please type "devmgmt.msc" in the Run dialog box and click OK to open the Device Manager window.
(iii) Click on the plus sign next to the "Display Adaptor" category to locate the display adaptor.
(iv) Right click on the display driver then click Uninstall.
You can download the display driver from the support site of the Computer manufacturer.
Sep 04, 2009 | HP Pavilion dv9000z Notebook
The on/off button isn't working. Green light doesn't come on and there is just an hp logo in the display box.
Check ou the following link
http://larrycrazyness.blog.com
I had the same problem and was able to fix it with the detailed documentation and photos.
Jul 16, 2009 | HP OfficeJet 7410 All-In-One InkJet...
2004 Chevrolet Impala tire pressure light guage
1. turn the ifnition to ACC or ON and turn the radio off
2. press and hold the DISP button on the radio for at least five seconds until SETTINGS is displayed
3. press the SEEK up or down arrow to scroll through the main menu
4. Scroll until TIRE MON appears on the display
5.press the PREV or NEXT button to enter the submenu. RESET will be displayed.
6. press the DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second.
7.Once the monitor has been reset, scroll until EXIT appears on the display
8.Press the DISP button to exit programming. A chime will be heard to verify exit.
The system completes the calibration process during driving
This only works if you have a RDS system on the radio.
Jun 12, 2009 | 2004 Chevrolet Impala
HP OfficeJet 7410 All-In-One InkJet Printer Logo
121 people viewed this question
Seeker5211
Seeker5211
