Question about GE Kitchen Ranges
For some reason oven or broiler will burn. How do I light pilot
    Brigadier General:
  • 3,513 Answers
Thanks for using Fixya.com
A GE range that is 5 - 6 years old uses a hot surface ignitor to light the gas. You need to remove the bottom pan in the oven and the burner and ignitor should be visible to you. There are two wires that go down to the gas valve underneath the oven that will be unplugged when you replace the ignitor. The ignitor is held in place by one or two screws which will probably be slightly rusted in position. Probably the reason why the oven wasn't very warm last week was because the ignitor was failing. Even now, when you turn on the oven, the ignitor will probably glow. This does not mean that it is good. The amp draw on the ignitor is what opens the gas valve. When the ignitor starts to fail the amp draw is reduced and the valve cannot open.
Using the model number you can confirm the age if you can.
Wishing U luck.
God Bless
Posted on Jul 17, 2009
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: oven will not ignite, but broiler and stovetop
Most modern stoves no longer have a pilot. The problem is more than likely caused by a bad igniter on the bake manifold. The following link explains igniter types and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Modern stoves are equipped with either a glow-bar or spark type igniter. These igniters do become weak with age and fail. This tends to be more common with the bake feature because it gets used more often. If the igniter is worn to the point that it longer produces the correct current potential or spark, the gas valve will not open and you will not have ignition. This is actually a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. Such a condition would be dangerous and could cause a flash ignition or explosion.
If the model number you have this listed under is correct, you can see an illustration of your stove at appliancepartspros.com. Just type in the model number and look under the "Gas Burner Parts" section for item number 28 (part #AP2014008).
If you have questions, or require additional assistance, please post back and let me know. I hope this is helpful to you.
Posted on Mar 03, 2009
How to light pilot light with sealed broiler oven
What make and model is it? I maybe able to help.
Aug 25, 2016 | Kitchen Ranges
Oven does not work: pilot light out? How feasible (how dangerous) to try to relight pilot light? T Phillips Winston-Salem, NC
Actually, your oven probably doesn't have a pilot light at all. In order to ignite the oven, it has an oven igniter. If you open the broiler, look up on the "ceiling" of the broiler to the back of the burner. There, you'll see a white block. That is the igniter. What it's supposed to do is heat up (electrically) and when it heats up enough, the gas valve turns on and the oven lights. What happens with these, is that the heating element on it opens from years of use and must be replaced. Inside the broiler door (usually) is the stove's model and serial numbers. Write them down and visit your local appliance parts store with those numbers and they'll give you a new one. (Usually around $30-$45 or so.) Also, you can usually change the igniter from inside the oven by removing the bottom drip plate, so that'll save your back a lot of straining. :)
I hope this helps and hope you have a wonderful holiday season!
-Jason
Dec 22, 2010 | Whirlpool GS460 Gas Kitchen Range
How to relight the pilot light?
There is an easy way to relight a pilot light in an oven/broiler if you do not have long fireplace matches and you are scared to stick your arm in with a regular lighter: Light a long stick of incense, but do not blow out the flame. Open the broiler door. Turn the oven to "broil" and extend the lit incense stick in \to the back of the broiler space. Wave the incense stick slowly back and forth below the broiler coil towards the rear of the oven until you hear the pilot light ignite, then pull the incense stick out, blow out the flame and insert into an incense holder.
Sep 19, 2010 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
How do i re ignite the pilot light
Hi
The surface on this range have standing pilots that must be lit initially. To light them:
1. Be sure the surface burner control knobs are in the "OFF" position.
2. Remove the grates and cook top.
3. Locate the pilot ports and light each of them with a match. Replace the cook top and grates.
Light the oven burner pilot in the following manner:
1. Be sure the oven control knob is in the "OFF" position.
2. Remove the broiler carriage.
3. Hold a lighted match at the top forward section of the pilot (See diagram). No adjustment is required.
4. Replace the broiler carriage.
Hope this helps...
Daniel
Aug 28, 2010 | Magic Chef 31000 Gas Kitchen Range
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven & broiler not working
    you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
    Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
    Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
    My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
    Bob Allen
    May 07, 2008 | Garland H283 Gas Kitchen Range
    Oven will not light
    ck your light bulb . and ck with meter see if you geting any voltidge
    Feb 05, 2008 | Amana AGR5735QDS Gas Kitchen Range
    Pilot light
    Ok the OVEN pilot light is located in the broiler part of the over (at the bottom) If you open the broiler and get a flashlight you will see the pilot light unit for the over at the rear on the top. What a cheap piece of **** these Galaxy ovens are.
    Nov 21, 2007 | Sears 61301 Gas Kitchen Range
    Kitchen Ranges Logo
    19 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
