Question about JVC DR-MH30S DVD Recorder
Loading... jvc dr mh30
Loading.. dr mh30!!!!!!!!!!!!!!!!!
  • Agim Qose
    Agim Qose Dec 16, 2007
    thanks Chicha,quale [capacitors]con difettodi secondario alimentazione[assy]...per sempio..c123..c1445...c..654..che contensatore electrolitico ????????????che zona di alimentazione?????Grazzia!!!aspeto un risolvere.MILLE GRAZZIA!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Agim Qose
    Agim Qose Dec 18, 2007
    Grazia!ho trovato difetto dell mio dvd rec jvc dr-mh 30s.. nell suo display apare solo LOADING..LOADING tutto il tempo.Difetto e in ...hdd maxtor diamondmax 16,,,160gb...quello e corrupt,[perche ho stotituita con un altra hdd come quell tipo di un altra dvd rec jvc dr-m30 e tutto OK...e devo aggiornare con programazione nuovo ,devo formatare e devo instalare un nuovo aggiornamento,mi aiuto qualcuno?dove scaricare questo aggiornamento[firmware]come si chiama,qualche sito?MILLE GRAZIA..aspeto qualche risposta da un spezialista di queste genere
    Problem Solver:
  • 15 Answers
Commonly this is cause by leaky capacitors in the secondry of the power supply SMPS ASSY.The PCB is located in the back right hand side of the unit.A visual inspection for any bulging of the capacitors will confirm this.
If you cannot change the capacitors yourself I suggest you take the unit to your local service center.
Posted on Dec 15, 2007
Dvd will not eject
Someone is going to have to open the unit and have a look to see if it is jammed in some way--often a disc will get out of position preventing it from ejecting--some can gently be moved and the unit may return to operation.
Dec 17, 2012 | JVC DR-MH30 DVD Recorder
How do i record using the JVC DR-MH30 DVD Recorder
Identify the input present on the rear panel and connect to device. The DVD can record what ever signal is inputed on these terminals.
You need to mention what your need is to clarify further.
Oct 01, 2011 | JVC DR-MH30 DVD Recorder
I have a problem with my dvd recorder.. every time i insert the disk it appear the no disc notice on the secreen, what should i do??
You can try cleaning the laser inside with a Q-tip and some rubbing alchohol, if you can take it apart.
WARNING! Unplug it first! It can cause blindness!
Dec 21, 2009 | JVC DR-MH30 DVD Recorder
JVC DR-MH30 keeps flashing ''loading'' after recent power cut
Measure the 5V line on the DVD drive,if to low replace the bad caps in power supply.There is an 22 microfarad elco you can upgarde to 47 microfarad to last longer.
If the 5V line is ok the problem could be the harddisk,this is not traceable without the proper software.
Aug 13, 2009 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Unit shows 'loading' continuously
This player is equipped to do a self power on test to all pain parts of the player to assertain everything is ok. The blue light will keep flasing until it completes its task and then the blue light will stop flashing and you you can start reusing it.....................sodeep
Jul 30, 2009 | JVC DR-MH30 DVD Recorder
JVC DR-MH30S DVD Recorder Image file
ciao! tutti vittime del dvd rec [jvc dr mh20-]..jvc dr mh 30...jvc dr mh 50..e un risolvere dell problema di mio jvc dr mh30..di 6 mese e roto trovo risolvere..difetto e nel hdd,160gb..e in corrozione..e roto hardisk,solo sistema operativo.......con softer COPY CLONE da iternet.scarica nell cd room..nel avvio dell pc,che sono due hdd,uno rotto ,e uno buono..guarda instruzione dell cd..e tutto ok,per copy di hdd..e tutto ok per legare poi nell dvd rec jvc dr mh 30..ho provato io e tutto io ho trovato hdd dell dvd rec jvc dr mh20..e io ho un dvd rec jvc dr30..ce un problema picollo dopo copy cloner,,mio dvd rec mi conosci solo perche e in origine da dvd rec jvc dr mh20[80gb]..cercho un hdd di dvd rec drm h30..opure jvc dr mh50..per copy cloner,mio hdd,per conosciere 160gb..opure 250gb..atentti problema di LOADING..e nell due alimenti di hdd..e suporte di dvd..sono quattro line..12v..terra..terra..5v....sono simille anche perhdd..anche per suporte dvd..controla nel condizione di non sono precise..voltaggio..persempio..12v=10v..opure 5v....4.2v..e perdita..da un contesatore electrolitica.e asciugato da lavoro aiuto da poco..non lo so aspettiamo nell mio e-mail....arivederci[ ]
Apr 14, 2008 | JVC DR-MH30S DVD Recorder
ok, this same problem happened to many other jvc dr-xxxx s, i think the only answer to this would be to get it serviced or just chuck it out. the cause for the annoying "loading" blinking light is a blown out capacitator, inside the machine itself i recomend u to not try to fix it d.i.y.
Mar 13, 2008 | JVC DR-MV1S DVD Recorder/VCR
Had this JVC recorder for a couple of years, It has always take ages to
boot up and start working now its stuck on "Loading" on the display.
Anyone no of a reset seqence that will restart the machine
Nov 20, 2007 | JVC DR-MH30S DVD Recorder
Unit in constant Loading state
Same problem on my JVC DR-DX5SU. Says "loading..." and will not respond. Factory solution is to quickly unplug and plug / or unplug for several hours and plug-in. I suspect that is to cold start and clear error flags. Did not work for me. I looked at the power supply board (immediately behind the DVD drive, on top of the hard disk). I noticed one capacitor was "bulging" on the top. See photo. Electrolytic caps should never be bulging - if anything, the top should be slightly concave.Cap was SAMXON 1500uF,10V,1400mA ripple - I suspect either voltage or current ripple spikes were exceeding its capability. Replaced it with a Panasonic EEUFR1C182 (, 1800uF, 16v, 2470 ripple current, to give it extra margin. Runs correctly now.1_30_2013_1_21_49_pm.jpg
May 11, 2007 | JVC DR-MH30 DVD Recorder
JVC DR-MH30S DVD Recorder Logo
757 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
