Question about Sony Cyber-Shot DSC-F505 Digital Camera
Memory stick error
When I turn the camera on I get a memory stick error, it beeps for about 5 seconds and will not let me take pics or video. The memory stick icon flashes and flashes C:13:01 on the screen along with "Memory stick error". ???????????????????????????????????????????? I have the same problem on the dsc-f505 new memory stick amd it won't let me use the file,format button but that could be because of the error don't know cause i'm just a dumb farmer
  • 1 more comment
  • murphy42 Nov 20, 2007
    but it won't let me format
  • murphy42 Nov 24, 2007
    as far as the card unlocked can't find where or if it is
    i've got a sore spot on my finger from pushing the damn thing in
    it still come up with memory stick error c:13:01 flashing
    when i go to format it doesn't let me do anything
  • murphy42 Nov 29, 2007
    My memory stick is a sony msac-m2 is on the adaptor and the little black stick is a sony memory stick PRO Duo 1GB magicgate and I still can't find the lock on the little sucker.
  • 298 Answers
Did you format the stick using the camera
if not then try that there seems to be a
problem when formatting with reader
Posted on Nov 19, 2007
  • 3 more comments
  • Eugene Merritt Nov 20, 2007
    Is the card unlocked ?
    can you get into the
  • Eugene Merritt Nov 21, 2007
    you should push the card in until it
    clicks shoud see it loading
  • Eugene Merritt Nov 25, 2007
    There is a little slide switch on the memory stick
    you slide it to unlock it should be on the terminal
    side of the stick you also get a error when the
    stick is not unlocked
  • Eugene Merritt Nov 29, 2007
    Is this the way your memory stick looks
    pic for illustration purposes only manual link is
    sony msac-m2 is an adapter I dont know what you're talking
    about a black stick the memory stick that came with the
    camera should have been 4meg and looked like the picture
    with a switch as shown
Five long beeps at a range of five seconds then, repeats
Five long beeps for a modern motherboards indicates a processor failure. If you wish to remove the processor and re-seat it (reconnect it to see if it begins to work again) make sure to get some thermal compound to put between the CPU chip and the heatsink. More info at:
POST AMI BIOS beep codes
  • 1 - Memory refresh timer error
  • 2 - Parity error in base memory (first 64 KiB block)
  • 3 - Base memory read/write test error
  • 4 - Mother board timer not operational (check all PSU to MB connectors seated)
  • 5 - Processor failure
  • 6 - 8042 Gate A20 test error (cannot switch to protected mode)
  • 7 - General exception error (processor exception interrupt error)
  • 8 - Display memory error (system video adapter)
  • 9 - AMI BIOS ROM checksum error
  • 10 - CMOS shutdown register read/write error
  • 11 - Cache memory test failed
  • 12 - Mother board does not detect a RAM module (continuous beeping)
Source: Wikipedia
Feb 28, 2011 | Computers & Internet
Sony DSC-P32 Memory Stick Error, "C:13:01"? When I went to review pics on memory card, camera would not scroll through and it would immediately shut off. Assuming it was the batteries, I...
The C:13:01 error code is the self diagnosis display of the camera to identify the cause of the issue with the Camera. This error code indicates the issue with the medium used in the Camera. You can try few steps to check if the issue can be resolved.
Try using different Memory Stick in the Camera.
Make sure that the Memory Stick used is compatible with the Camera. (The maximum capacity that can be used in the Camera is of 2GB Memory Stick PRO Duo.)
Format the Memory Stick in the Camera and check if it works. (Formatting the Memory Stick will delete all the files saved in it).
This may happen if the files in the Memory Stick is damaged or corrupted.
Try turning the camera power off and on.
Remove and re-insert the Memory Stick several times.
Insert another Memory Stick in the Camera to check if the issue is with the particular Memory Stick.
Try resetting the Camera and check if it helps. To reset the Camera, press the RESET button located inside the jack cover using a sharp pointed object.
If the issue happens with different Memory Sticks after performing all the steps, service may be required.
Thanks for using FixYa.
Dec 05, 2010 | Sony Cyber-Shot DSC-P32 Digital Camera
Problems with Foxconn 6100K8MA-RS Motherboard memory upgrade
This is an oldtime POST code memory error. Likely that ram is either installed wrong, bad RAM or the mobo doesn't like one of the memory sticks.
You must count the beeps.
Mar 17, 2009 | Foxconn 6100K8MA-RS Motherboard
Problem with a memory stick
You need to format the memory card within the camera, else you will receive this error.
Apr 02, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Memory full message in error
Remove some pictures from the memory stick Or copy them to your computer. Actually your memory stick is full. If you have no memory stick in the cam then purchase a new one for it. The cam memory is not enough to store many pictures.
Mar 28, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Memory stick error
If it says there is a memory card error it means there is a problem with the memory card or the capacity of the memory card is too much for the camera if u have tried using a diffrent memory card and the camera is compatible with it that says that the camera is defective
Feb 17, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Samsung scd103 camcorder memory card
From the manual:
“Memory Stick PRO” can not be used with the SCD103 MODEL.
You MUST use only a memory stick, not the PRO
Nov 18, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Memory stick error
Try using another memory stick, or insert a confirmed good memory stick, if OK, the memory stick is defective, if the same error, try pressing reset at the back of camera, a small hole beside the the DC jack. if OK, then fine, if still the same, camera needs repair. thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Accessing pics from memory stick
This is a computer error. Check images are there in the camera by looking at the review screen. Then check you have not 'locked' the stick or 'protected' images turn off the protected then try
Aug 14, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Memory card problem
Download PC Inspector from www.convar,com run the stick through this program- if the images are there it will find them But of course no images may have been recorded Sony Tech Help Team will tell you more about the meaning of 'Access'
Jun 23, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-Shot DSC-F505 Digital Camera Logo
174 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
