Question about Kenmore 63942 Dryer
Kenmore 80 series dryer is not getting hot - Kenmore 63942 Dryer
    Genius:
  • 1,122 Answers
Remove the back panel and check the heater box fuse on your right top,also check the heating element right side bottom,make sure done of the wire is broke inside-mike
Posted on Jul 17, 2009
5 Suggested Answers
  • 91 Answers
SOURCE: Kenmore 80 series dryer
repl/motor
Posted on Jan 03, 2009
  • 119 Answers
SOURCE: Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Posted on Sep 24, 2009
Testimonial: "Thank you for your reply!"
hunter19_46m
  • 7482 Answers
SOURCE: can't find kenmore 80 series dryer drum belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Also for a manual I will include this website:
http://www.applianceaid.com/
Good luck,
I hope this helps
Posted on Nov 16, 2009
Testimonial: "many thanks... sounds like a lot of work unlike my old dryer"
  • 1122 Answers
SOURCE: I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Posted on Feb 03, 2010
The dryer isn't getting hot
Here's a good troubleshooting article on them:
http://www.ehow.com/way_5389575_troubleshooting-kenmore-series-dryer.html
Keep in mind, it is an older dryer, but that series is known for being really good. If the article doesn't check out, I would suggest calling in a technician as it's possible something got damaged in the move/
Dec 31, 2012 | Kenmore Dryers
Kenmore 80 series the drum will not turn but dryer gets hot
more then likely, the belt broke that turns the drum.
Jan 24, 2012 | Kenmore Dryers
Over heating kenmore 80 series dryer
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 31, 2011 | Dryers
Kenmore 80 series electric dryer doesn't get hot
The eletrical heating element is most likely faulty (broken and open-circuit) and will need to be replaced: this is non-trivial exercise involving main and dangerous high voltage better left to a professional repairman.
Jul 28, 2010 | Kenmore Dryers
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore dryer does not heat
I have a kenmore series 80. Had the same problem...the fix was replacing the gas coils. The dryer would get hot for about 10-15min then nothing. The gas would stop firing but you could see the igniter glow over and over again. Hope this helps.
Apr 02, 2009 | Kenmore Dryers
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
775 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
