SOURCE: re; control board
behind the display control youll find two slots for inserting a screwdriver and releasing tabs that are holding the control up, no screws just 2 press to release tabs, might be a little awkward to feel might have to twist your head in a little sideways to see them. there is or at least should be a tech sheet mounted to the underneath of the cabinet, just behind the kick plate on rightside
SOURCE: New High Voltage won't program
if connected right have the parts person that you purchased it from warranty the part back to whirlpool as deffective and have them order an new one
it will not cost you and reinstall the new one that you get
SOURCE: I replaced my HV Control Board on my maytag
First did you program the board correctly and second make sure all the connections to the board you replaced are in correctly.
SOURCE: need reset code for maytag fridge MFI2266AEU. Just
My sticker is missing. What code do I use?
SOURCE: After installing a new mother
It's board are already programmed so check it's wiring for open, look for deformed component it may cause it not buttons to work. Also do not overlook the possibility of a factory defect control board sometimes it do happened. Be sure that you installed it correctly the same as the old one. Look for loose connection.
Thanks for asking. Good luck.
