SOURCE: Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
SOURCE: MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
SOURCE: water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
SOURCE: Magic Chef 20lbs hd won't agitate
Try these
pls rate my suggestion.......
