Question about Brother FAX-T74 Plain Paper Thermal transfer
  • 1113 Answers
SOURCE: Brother MFC 3220c machine error 41
Not worth fixing I'm afraid
Very common, error 41 is stuffed print head, fix is replace head cost about $250 fitted
Time for a new printer and beware of after market inks that you feed it some do more damage than good.
Posted on Jan 13, 2008
  • 47 Answers
SOURCE: Brother Fax 4750 System error 76
try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
Posted on May 12, 2008
  • 130 Answers
SOURCE: Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
Posted on Jun 11, 2008
  • 215 Answers
SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
Posted on Jan 28, 2009
  • 328 Answers
SOURCE: drum error message
check the silver spring loaded contacts inside the drum cavity make sure they casn be pushed in and spring back out. Also clea them with a dry cotton swab
Posted on Jun 11, 2009
SOURCE: Fax canon B120, Error code :##342, Error Message: "Check Printer"
15bdaa2.jpg Fax Canon B120
Posted on Jul 26, 2010
0 characters
1 Points
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Fax Machines
Drum error message
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
Want to change its language from Norweign to English
i hope that you have the manual, it should tell you how to change the language when you do a machine set up, press menusey button and start scrolling throgh the different menu good luck
Jan 13, 2009 | Brother FAX-T74 Plain Paper Thermal...
Brother Fax-t74
I have found a link to an online version of the manual.
Brother Fax-t74 Manual
Sep 30, 2008 | Brother FAX-T74 Plain Paper Thermal...
Brother FAX-T74 Plain Paper Thermal transfer Logo
24 people viewed this question
Top Brother Fax Machines Experts
Paul King
Paul King
john archer
Are you a Brother Fax Machine Expert? Answer questions, earn points and help others
