Question about RCA L32WD250 32 in. LCD HDTV
No channels after auto channel search. - RCA L32WD250 32 in. LCD HDTV
  • 147 Answers
Replace the digital main pcb.
Posted on Jul 17, 2009
5 Suggested Answers
Danmart
  • 291 Answers
SOURCE: can't get the channels to enter into the channel list
A lot of the " auto channel scan " etc. need a certain signal strength. you could have too meny tvs,equipment or anything connected to the "signal giver" that is sucking the signal strength.Not just turn off ALL connections to signal but disconnect the antenna 'input' to any equipment (sometimes people connect cable wires to radio receivers for stronger & better signals.)
You could have a open circuit to the input of the equipment in trouble.If you know how to get inside (with out killing yourself) connect an antenna directly to the end of the line of the intanna input INSIDE of the TV. if the signal comes in and the tv 'autoscans' and locks channels, then you have a open wire leading into the circuit.
p.s. BE CAREFUL!!, IF YOU don't know how or what you are doing.........DON'T DO DAT !! [that]
Posted on Nov 30, 2008
SOURCE: No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Posted on Dec 10, 2009
SOURCE: I cannot get my Olevia 226 T11 to do an auto
Check the Power Up setting to be sure it is starting up in HOME mode rather than SHOWROOM mode. In showroom mode, many settings cannot be changed.
Posted on Feb 15, 2010
SOURCE: I get no sound or
I'm having sound problems with Gem too, as are others, apparently. If you are getting program info but no picture for either of these, however, I suspect that you may only have a SD digital receiver, rather than a HD (High Definition) one. Can you receive the One HD sports channel? If not, that will be it for sure.
Posted on Oct 11, 2010
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
Auto Channel Search, how do you accomplish this.
Use your Insignia remote to select the initial set up procedure and run auto channel search.
Mar 03, 2015 | Insignia Solutions NS-24E200NA14 24" LED...
Why am I stuck on one channel
There is only one channel in auto search. Just open searching menu and auto search again your new channels.
Jun 01, 2014 | Element ELC-HS321 32 in. LCD TV
Need to scan channels
you can do the auto search channel. just press the tv menu and then find the channel search and select auto search. so that all available local channel will tuned.
Aug 30, 2012 | Insignia NS-LTDVD19-09 LCD TV
The channels of our tv have been jumbled
did you tried with auto search program so that all the available channel will be search from lower frequency to higher. or you can manually tuned the channel so you can stored it in the right channel.
Aug 02, 2012 | Televison & Video
Sep 30, 2009 | Vizio VX37L Television
Programming channels
The only thing I see in the Manual is to do an auto search which will scan all available channels and saves them to memory. the faxtory setting is auto search. the search allows you to manually search for available channels. in this mode, available channel must be stored individually. the program sets your favorite channel to appear when the tv is turned on. the range is from channel 0 - 255. i hope this helps.
Sep 15, 2009 | Trinity CT-V710 7 in. Portable TV
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
I need the code to do an auto channel search for my lg tv so i can go up and down from channel to channel instead of typing the number to the channel in
Your auto channel search should be in your menu on the TV. Find your menu button on the front of your TV or on the remote.Make sure before you do a auto search you set your TV to cable, that can also be be done through your menu screen. If you can change the channels on the remote and control the volume your remote is already programmed.
Jul 15, 2009 | Quasar SP-2725 27" TV
Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
Jul 28, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
RCA L32WD250 32 in. LCD HDTV Logo
82 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
