Question about Brother PE-150V Computerized Sewing Machine
Time janome 3018?
Bobbin thread bunches ! happen when tryed sew heavy material.
  • Brother Master
  • 1,388 Answers
For a comprehensive 5 page illustrated tutorial...Check this link
Posted on Oct 18, 2011
  • 55 Answers
When you say 'bobbin thread bunches' i take it that when you look at the underside of what you have sewn it looks messy. if this is the case and the machine is threaded correctly and the the needle thread is tight enough to bend the needle a little when pulled (with presser foot down) it will most likely be that you need to increase needle tension (maybe to max) when sewing thick fabrics with thicker than normal thread.
if the the needle does not bend a little you may not have the thread in between the tension discs, or there may be thread or lint caught in the tension discs preventing proper tension (try pulling a thin rag through the tension discs to dis-lodge any foreign matter).
scott.
Posted on Jul 26, 2009
My Janome MyStyle 16 keeps jamming - thread bunching in the bobbin cavity. Have tried everything but keeps happening... How can I fix this??
PDF]INSTRUCTION MANUAL - Janome
janome.com/siteassets/support/manuals/.../inst-book-7318-english.pdf
making any other adjustments mentioned in this owner's manual. ..... 16 q w e r t. SECTION 3. BASIC SEWING. Straight Stitch Sewing. Machine setting: q Stitch ...
How to Thread a Janome Sewing Machine - YouTube
? 6:55
https://www.youtube.com/watch?v=NUsT0plWt6Y
Mar 1, 2013 - Uploaded by Easy Sewing for Beginners
In this video I show you how to thread a Janome sewing machine ... I've unwrapped it and started reading the manual and it wasn't easy to see ...
Nov 26, 2015 | Janome Sewing Machines
My Janome 3018 will not wind a nice tight bobbin. They are loose and spongy. This machine is brand new. I have double checked that it is threaded properly and the thread is in the correct place and
You are not exactly threading the machine when you wind the bobbin. So follow the directions for winding the bobbin, make sure the thread fits under the little revolving wheel, and make sure that the stitch part of the machine is disengaged.
Jan 01, 2015 | Janome Sewing Machines
Embroidering in blue thread, and the white bobbin thread was coming through on the material. Adjusted the tension to -8, sprayed the bobbin casing and area lightly with WD40, changed the bobbin, changed...
The white bobbin thread was showing on the top of the material correct? Make sure bobbin thread is in the tension correctly, check the top thread spool and make sure thread is not caught around it, if you have a manual top tension make sure that is set correctly. Personally I would never use wd40 in a sewing machine, sewing machine specific oil is always better. You seem to be describing two different problems. The thread bunching is probably from the thread jump out of the take up lever.
Sep 12, 2013 | Brother Sewing Machines
John Lewis mini sewing machine
This was really helpful for me fixing my daughter a John Lewis (janome) mini sewing machine, and now can get the bobbin thread up again, however, when you sew, the thread is not staying in stitches, just coming off the material completely. I tried forcing the gears on one more time but then it didn't pick up the bobbin thread again so went back to the other gear position. Any ideas of what to try and get it stitching again? Thanks
Apr 02, 2013 | Janome Mini Compact
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
JanoneDc3018 thread bunches up .
Are you using heavy thread for the top stitching? If so you will need to tighten the top tension. You would think if it is thicker thread that you would need to loosen the top tension but you have to tighten it to help pull it up through the fabric. If you use heavy thread in the bobbin you would have to loosen the bobbin tension. Check and make sure the thread is seated in the top tension and make sure there is no lint in the tension disc. It is definitely a tension issue. Hope this helps.
Jul 16, 2009 | Janome 1017 Mechanical Sewing Machine
Cotton keeps getting knotted from the bobbin
upper tension is wrong or upper threading is wrong (problem is always on the other side of the bunched thread)
Jul 07, 2009 | Janome Sewing Machines
Brother PE-150V Computerized Sewing Machine Logo
206 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
