Question about Samsung HP-R5072 50 in. Plasma HDTV
BOTTOM HALF OF SCREEN GOES BLACK R A MINUTE OR SO THEN RETURNS T NORMAL
  • 147 Answers
Remove the back of the tv.disconnect and reconnect the ribbon cables into your buffer pcb.if this does not correct the problem replace the buffer pcb in that location where the screen is going black.you also could have
a defective panel if the buffer pcb does not correct your problem.
Posted on Jul 17, 2009
SOURCE: Bottom half of the screen goes black
Make sure you have the text turned to off in the closed caption settings
Posted on Apr 23, 2009
  • 80 Answers
SOURCE: Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
Posted on May 21, 2009
  • 4 Answers
SOURCE: Bottom half of the screen goes black frequently.
You can start here: http://www.support.philips.com/support/catalog/catalog.jsp;jsessionid=87CE21B6A8264B83B8D00501ADACA8BF.app107-drp1?_dyncharset=UTF-8&country=&categoryid=FLAT_TV_CA_US_CARE&userLanguage=en&navCount=1&groupId=TV_GR_US_CARE&catalogType=&navAction=push&userCountry=us&title=Flat+TV+(plasma%2C+LCD)
Enter the exact Model Numbere in the search text field.
First verify the exact Model Number of your TV. Mine is a 42PF7220A/37.
go to:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7220A/37&scy=us&slg=en
On this page I found listed under "Software2.gif & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
I downloaded the compressed file and extracted it to a USB Flash Drive2.gif.
After you extract the file you will have 2 files...."autorun.upg" and a "readme.txt".
Make sure the USB Flash Drive2.gif has only one file on it (autorun.upg)
Make sure the TV is turned off.
Put the USB Flash Drive in any of the USB ports on the TV.
Turn the TV power on with the Power Button on the righthand side of the TV.
The TV will display an Update screen.
Let the TV run through all 3 processes.
Turn the TV off and remove the USB Flash Drive.
Power the TV back up.
Hopefully the Updates fixed the problem.....
Posted on Sep 29, 2009
  • 4 Answers
SOURCE: Screen will periodically go half black. Then it
When you have video display problems such as shadows and lines that go away after warming up, or come and go during viewing, it is usually the LVDS cable and T CONN board going bad. The screen can have one of the following or combinations of blurs, different layers of brightness and lines. It could be the back light but most of the problems with the LNT4661F have been this.
I had the shadow and line problem and replaced both the cable and board for $120 and that fixed my problem. Since I had the TV apart, I went ahead and replaced the capacitors on the power supply board so I wouldn’t run into the clicking problem that also affects this model TV. You can find the parts numbers for the LNT4661F cable and board below. You can find links to YouTube ( Part 1 & 2) to show how to replace the capacitors. Good luck.
Samsung A/S-T CON BOARD BN81-01312A
Samsung Lead Connector LVDS BN39-00883A
YouTube (Part 1) http://www.youtube.com/watch?v=Mm51C_RDIZE
YouTube (Part 2) http://www.youtube.com/watch?v=BNHHrgX_6cs
Posted on Dec 18, 2009
  • 8457 Answers
SOURCE: Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Posted on Apr 12, 2010
Apr 12, 2010 | LG 42LC2D 42 in. LCD HDTV
Bottom half of screen goes black
This is because full pixels of your TV is not getting invoked at the beginning .If you are able to view the picture as normal after 1 or 2 minutes, its fine.Else you need to call to service center and get this problem fixed.
Aug 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Bottom half of screen is black
its ur diaplay problem.. go for a change of new display...
Jun 30, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
May 19, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Apr 23, 2009 | Televison & Video
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Half black screen on projection tv
Sounds like the vertical area like Output, but I would look for bad caps first and resistors. In this area
Sep 14, 2007 | Televison & Video
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Samsung HP-R5072 50 in. Plasma HDTV Logo
300 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
