Uninstalling and turning device on and off does nothing at all
SOURCE: My samsung galaxy tablet is
It appears your Galaxy is faulty and it will still be under warranty. I suggest you take it to the supplier to get it repaired or replaced under warranty.
If you try to repair it yourself, you will most likely void your warranty.
SOURCE: Why i can't download yahoo
Here are the facts.
1. Samsung Galaxy 10.1 is running Android 3.1.
2. Yahoo messenger is ported till Android 2.2.
Solution:
1. You may have to wait for sometime time till Yahoo compiles IM in Android 3.1.
2. Use android 3.1 provided IM client to connect to Yahoo Messenger.
SOURCE: SAMSUNG GALAXY TABLET NOT CHARGING OR TURNING ON
Hi buckpot2001,
To correct this issue, please follow the steps below.
1. Press and hold down the power button whilst at the same time touching the screen (you may have to wait up to 30 seconds as it clears the system).
2. You will then notice the battery indicator pops up.
3. The Tablet will then reboot. Everything goes back to normal.
4. If that fails to work, connect the power cable and repeat the above steps.
Hope it helps.
Thank you for using FixYa.
SOURCE: Samsung galaxy tablet is frozen
Couldn't even turn mine off ... read up on this.
SIMPLE SOLUTION: Hold the power button down for more than ten (10) seconds. WORKED!!!!
