Question about Dometic Rooftop RV Air Conditioner
Duo therm ac not working
I have a 2005 coachmen captiva. I turned on the AC for the first time this season and this is what happened. The ac unit fired up like everything was O.K. but no fan turned on. After a minute or so the ac unit vibrated and shut off. Is there a seperate fuse somewhere for the fan?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
If your Rv is wired the same as a Mirada it will still be on a 110volt transformer and i am guessing that you would have 110volt circuit breakers i imagine you would have checked those ?.Did you have your thermostat (temperature control) set lower than air temperature?You may be able to try the fans only by putting the control unit on manual and trying High and low fans.I have had a time when i turned my unit on and nothing happened and then an hour later it worked!! Also who converted your RV if it was carcon the electrical work is disgraceful as is the rest of there work.
Posted on Oct 12, 2012
  • Dometic Master
  • 3,361 Answers
Make sure the fan blade turns freely when off. Not bound up anywhere. Check or replace the fan motor capacitor.
Posted on Jul 17, 2009
Dometic Duo Therm RV AC makes clicking noise when turned off
The braker is getting weak and needs to be replaced the act should be cleaned as the coils get dirty and make the units work harder
Jul 19, 2014 | Dometic Heating & Cooling
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Duo Therm AC won't cut off with thermostat
Hi, sounds to me like the thermostat is at fault.You have done nothing wrong to it but cover it up. The t-stat is what controls it, turns it on and off. The only other thing that would keep it on all the time would be that the thermostat wiring could be touching together from the stat up to the unit. You might check that before replacing stat. I have seen this many times.You can start the unit and go up top and disconnect the stat wire and it should stop the unit.Then its either the wire or stat.Let me know what you find,
Sincerely,Shastalaker7
Nov 04, 2009 | Heating & Cooling
Duo Therm AC/Heating not working at all after tripped breaker.
I had to get on the roof of mine, remove the cover and manually spin the fan. Add a little oil to the shaft where it goes thru the bearing. All of this is done on the roof side. Mine required this procedure every spring. Duotherm realizes they had a problem and have since corrected it but they don't deal with all of their customers that had the original problem.
Jul 20, 2009 | Heating & Cooling
Penguin Duo therm AC bogs
Try replacing the wall thermostat with an electronic unit. It sounds like it is short cycling. If there is not at least 5 min delay before trying to restart the compressor this is what happens. Most electronic thermostats have a delay feature built in to solve this problem.
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
382 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
