there must be some problem in the Drain line/air gap - A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Good Luck!!
Thanks
Popular Solutions for Ariston Technologies LL64WNA
ariston lsi 61 dishwasher kept stopping half way through wash cycle.but now unable to select any...
(More)
ariston lsi 61 dishwasher kept stopping half way through wash cycle.but now unable to select any program as green light comes on for a few seconds then goes out.the power light is on ok
I have the above dishwasher and it stops half way through the cycle and refuses to drain. The salt...
(More)
I have the above dishwasher and it stops half way through the cycle and refuses to drain. The salt and rinse aid level lights are on. Could it be that I just need to top them up. I have checked the instructions but they are not very clear on whether low levels would cause the washer to stop working. Thanks in advance.
We live in Perth Australia and have this dishwasher in our rental house. It does not have a manual...
(More)
We live in Perth Australia and have this dishwasher in our rental house. It does not have a manual and we are having trouble with it. Please help.
The last time it broke down i replaced the element when it carried on for another two years.I have...
(More)
The last time it broke down i replaced the element when it carried on for another two years.I have now replaced the thermostat next to the element but still no luck can you sugest what else to try. The fan is running whilst drying and there is power to both the heater element and the thermostat but nothing completes the circuit
We bought a new machine for our little gite in France to rent out. It has never been used and only...
(More)
We bought a new machine for our little gite in France to rent out. It has never been used and only now are we renting the gite, so started the new machine to check it out. The eco light/soak light flashes and it says that the filter is blocked, but as it is brand new - of course it isn't! Filled salt to required level and that light flashes also. We have tried filling it manually with a little water and checked all inlets and outlets and even took the bottom panel off to check coneections, all fine and obviously brand new. As we didnt try it last year, it is out of warranty!!! Can anyone help - the filter is clean and all connnections are fine!
