Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
When changing channels, sometimes the color is greenish/purple. Return to the previous channel and the color is fine. I've replaced the DVR from the cable company so I'm assuming that the problem is with the TV. Help!
  • 147 Answers
Try a dvd into input one on the tv.if this shows
good with no color problems.then call the
cable co.if you have another tv check the signal with that tv.if the cable is good then
suspect the tuner in the tv.
Posted on Jul 17, 2009
Ge 20gt610 tv
It sounds that the degaussing posisor resistor at the circuit has failed. dd297058-fa58-4c22-9e19-4c58832b6fca.jpg42497af9-8189-4bdc-99ba-85f3aca519fd.jpg
It will look somewhat like this.
Jun 05, 2013 | Televison & Video
Picture was fine on all 4 cameras then it lost color and started rolling on the monitor .
You have the wrong settings on the DVR, go to DVR menu system or camera settings and change the setting from PAL to NTSC.
Jan 28, 2013 | SWANN 4-channel/camera Dvr Surveillance...
My P-73 sometimes has a strange purple /greenish color on the display like it is not rendering the colours correctly. Also it shows a strata of lines. Often in bright sunshine. But sometimes OK. Any...
Please open its cover and re-insert its CCD assy flexible cable it is loos thats why purple and greenish color appear. Its part no and description is 1-860-194-11 FP-854 FLEXIBLE BOARDeedc66b.jpg
Jan 24, 2010 | Sony Cyber-Shot DSC-P73 Digital Camera
Just bought a Sony XBR9 and Comcast gave me a Motorola DCT6200 box which has a DVI output to a HDMI input into the TV. When switching from a HD channel to an analog or digital channel, the picture is...
I am having the exact same issue. It started happening within the first few hours of turning on the XBR9 for the first time. I also have a Motorola box from Comcast. This did not happen with the HD TV that was hooked up previously. Did you return the TV?
Jan 07, 2010 | Arris DCT6200 DTV Receiver
Unable to receive signal through my Comcast box, but signal is fine from the cable???
It turns out that the DVR has to be on channel 3, and the channels are controlled by the cable box! I somehow had missed that part. With the DVR on channel 3 and the channel being changed through the cable box it is very awkward to try and do any recording unless it happens to be what you are watching, so I have basically given up the whole idea and am planning to return my cable box an go back to basic.
Oct 06, 2009 | Panasonic DMR-EH50 DVD Recorder
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Picture is black and white
If you have it connected to the 'antenna input' on your TV, change the channel up or down, and then back to 3/4 as appropriate. Sometimes the signal from the machine does not match exactly what the TV is looking for, but the TV will figure it out after you change the channel up or down. The AFC (automatic frequency control) will then try to re-tune the channel.
If you have it connected using the composite, and r/w audio, then you likely have a problem inside the DVR.
tom
Feb 16, 2009 | Protron PD-DVR100 DVD Recorder
Light in color and won't copy dark. It come out light purple
you may try
1) color ink cartridge--- no enough ink or the cartridge ink channel dryer and constipated, refill ink and put down the cartridge bottom surface to water a little for 1 hr, then set back. or change a new cartridge if not fixed go next
2) print head--- the ink channel dryer and constipated, take out print head clean it's ink channel using cleaner or steep in water (do not touch circuit pin area with water) 20 minutes or longer. then set back and test (you can do more times), still not fixed, your print head have to change.
Feb 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Playback in B/W
no you can't transfer then to another hard drive because of the format they have been saved in, burn them to dvd if you can, try reset the machine to factory settings, this in theory should ironout any clitches
hope this helps
regards
Nov 17, 2008 | Tivo R54040 140-Hours Video Recorder
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
95 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
