Question about Minolta EP4000/5000 CS/PRO Copier
Getting a move collater closer error but there is no smudge room btwn copier and collater
  • mrpendous Jul 17, 2009
    Hi, I must be missing some part because the upper and lower end dont line up evenly and thats why I think its not closing,, plus I dont see anything to lock the two together.. help!!!!
    good possible solution
  • 2,359 Answers
Did you move this copier recently?
Without spending too much troubleshooting,lets separate the collater and the copier.
Clean both ends and spend more time on the contacts and magnetic part,
The last item to inspect is the cord.
During a move,the mover can damage the cord and stop sending the CLOSED signal to copier.
So to sum it up,clean contacts and check cable for damage.
Good luck
Posted on Jul 17, 2009
  • Vincent_G
    Vincent_G Jul 17, 2009
    Back in my Canon copier day,the unit is long and we has to add shims to level it.
    In order to fix you contact problem you has to locate the locking system that send a CLOSED signal to the copier.
    It can be a micro switch,BIG contacts,magnetic sensor or locking latch on both side of the unit.
    Make the connection and add the shim on the floor to keep the contact.
    DO NOT SEE THE CABLE that connect between the copier and collater?
    Make sure it's in good condition.
Bizhub not collating when stapling
did you select collate in the print driver, try reloading the driver check the web site
Self Help Product Support Konica Minolta Business Solutions Inc
Apr 01, 2014 | Konica Minolta Bizhub 222 Black and White...
Had a mfx-2830 donate to our church. Looks like it has a collator on it but see no option to select to collate. Any ideas?
The collate button is an electronic one on the LCD panel...not a separate button.
Now if the display is not registering the "finisher" / collator as being there then it is possible that something is wrong .. maybe the collator/finisher was physically installed onto the machine but maybe the electrical connectors were not plugged in. Ask the person/company that donated it if it was working.
Feb 03, 2011 | Muratec MFX-2830 Black and White Copier
Second hand Ricoh FT7950. Paper wont feed from
Going strictly from memory as this is an older model.
With the machine sitting ready to make a copy open the finisher door and close it . Are there any signs of life ie rollers spin tray moves stpler homes up?
IF yes I would look at the finisher entrance sensor as these get pretty dirty ith paper dust(or could be out of alinment from moving.
IF No then I would look at the finisher connector inspect for any damage .
Hope this gets you in the right area
Apr 03, 2010 | Ricoh FT7950 Copier
Printing page order
under print settings make you have "collate" option checked. There are different ways to find this depending on which operating system you are using.
May 26, 2009 | Brother HL 1440 Laser Printer
Collator light is on the trouble board
Hi Greg,
I'm real familiar with the NP 6050 copiers, can you tell me exactly what the display is saying.
thanks
Apr 09, 2009 | Canon NP 6050 Copier
I can't find a driver that will allow me to utilize the stapler and collator on my estudio 3511 for on my Mac computer. I can use the printer on my mac....but the current driver doesn't include options...
Hello sir; It don't have driver for stapler or collator, because these two unit are controlled by copier cpu,therefor your computer only can deal with copier. the copier cpu got everything you need.
Mar 22, 2009 | Toshiba Estudio 200L Copier
Print error job storage
The printer needs to have RAM drive off, mopier mode disabled. Also the device settings for the printer needs to have Printer Hard Disk set to not installed and job storage and mopier mode set to disabled.
Jan 15, 2009 | HP LaserJet 4200 Printer
I am running Microsoft Word 2003 and have an HP 1320n printer. My problem is that when I print more than 1 copy the pages do not collate even if the collate box is ticked in the print dialogue book and so...
HP 1320 print driver is a universal print driver covering several printer models.  Collating only works on HP printers if you have a multiple exit tray system for commercial based laser printers similar to finishers on a copier.  They have to have room to keep the copier together before they can be collated.  On a standard configured 1320 there lacks any space for finishing tasks.
This support bulletin on hp.com can provide you the answer:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01366409/c01366409.pdf
Sep 10, 2008 | HP Computers & Internet
KONICA MINOLTA C450 VXL Printer - When stapling multiple copies it staples all the copies together rather than each one separately as required. I use vista operating system.
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
Jul 23, 2008 | Office Equipment & Supplies
Canon copier np 6545
E540 is a sorter/collator problem
You can unplug the sorter and move it away from your copier then swith off then on again and the copier will work and you can still sort via the document feeder.
here is the error code disription...
E540
Cause..
• Bin shift motor (fails to rotate)
Discription....
• The operation does not end within a
specific period after the motor drive
signal has been generated.
• Clock signals from the clock sensor
of the motor are absent for a
specific period.
• The input signal from the lead cam
position sensor does not change for
a specific period.
Jun 08, 2008 | Canon NP 6545 Copier
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
