Question about Zanussi WJS1265W Front Load Washer/Dryer
Washer/dryer E90 keeps coming up, and the lights go out.
  • Rod60 Jun 03, 2008
    during wash / dryer cycle washer stops and E90 shows
Try this site. It seems to have worked for me!
http://www.letsfixit.co.uk/html/washing_machine_faq.html
Posted on Apr 25, 2008
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded ยท E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    When turned on machine, no lights came up, then all lights lit up and beeped and on panel E90 kept flashing
    An E90 error indicates some sort of communication error between the two boards that control the washer. Usually it's a problem with the wiring. (At least for Electrolux and related washers, E90 is a communication error.)
    You can try unplugging the washer overnight and then trying again. This resets the board. Otherwise, you need to open the washer and use an electrical contact cleaner. Check all the wiring for any corrosion or solder issues. This will be time consuming.
    Alternatively, you could replace both control boards (usually comes a large fraction of the cost of a new washer when you add the repair man's time). You usually can't tell which of the two boards are bad so replacing just one frequently doesn't solve the problem.
    I hope this helps.
    (if you add a comment with the make and model of your washer, I'll check the parts cost/availability if they are at my usual sources.)
    Jun 26, 2011 | Washing Machines
    Fault code E90
    E90 appears to be caused by faulty connectors to the main circuit board which appears in the bottom right corner, if you're looking at the washer from the front with the lid off (looking down into washer). This is fixed by reseating, cleaning the connectors.Also drying it out with a hair dryer has been known to help.
    May 06, 2011 | Zanussi Washing Machines
    Machine flashing E90 and not working.
    The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer.
    Jan 16, 2011 | Washing Machines
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    ZANUSSI ZWD1471S
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Apr 04, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
    Washer whilst washing keeps flashing up with E90
    Click on Zanussi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
    Nov 06, 2007 | Zanussi FJS1225W Front Load Washer
    Error E90
    That happened to mine, and apparently it is the connection to the control panal at the front of the machine or the desplay unit (4 blue wires). Take the top off and wiggle them around or re-connect if any are loose. Mine worked for one wash and then started displaying E10........so i'm not amused and I think i may end up getting a hotpoint!
    Nov 09, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
    Zanussi WJS1265W Front Load Washer/Dryer Logo
    138 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
