Will not wash only put in wather and drain - Washing Machines
  • 6,784 Answers
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor. If this dose not restore normal wash functions, you will then need to replace the control module or timer.
Posted on Jul 17, 2009
My kenmore serie 300 washer only wash with cold wather no hot wather
If I understand, you are saying that you are not getting any hot water coming into the washer. First, I would make sure that you have hot water available at the washer spigots. SLOWLY unscrew the hot water hose at the hot water spigot and see if you have hot water available. If you do, the problem is usually at the water inlet solenoids, or if you are lucky, the water screen filter. Turn off the how water spigot and unscrew the hose at the washer. There is a screen there at the washer water inlet, see if it is clogged. If not, the problem is most likely the solenoids. To replace the solenoid unit requires some disassembly of the washer.
May 18, 2016 | Kenmore Washing Machines
Wont drain in automatic cycles
maybe is necesary to set the drain operation in the automatic cycle,like you can set the temperature of the wather ,the time to prewashing and so on.
Dec 26, 2013 | Whirlpool Washing Machines
Whirlpool cabrio wtw6700tw1
You can buy a new pump from partsclinic.com The following link is for the part and a video on how to replace it
http://www.repairclinic.com/PartDetail/Drain-Pump/W10217134/1472275?modelNumber=WTW6700TW1
Oct 13, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My kenmore elite washer model # 110.24082200 is leaking from bottom. No visible leak from back panel acces...
my kemore whasing machine model10010 .25864400is not drain all c los left sam wather in dram and sound of water pamp like cenot turne tenks Bruno
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
No wather go out
what is washing machine front load? if yes we need to replace the drain pump orelse c;ean the pipe line to to drain pipe,if top load also clean the pipeline of drain remove some foreign object that block the line in drain.
Jan 01, 2011 | Washing Machines
The dishwater is not draining when the washer is running. What should be checked to help resolve this problem?
is wather filter dirty, or defective/stucked wather pump.
check the water filter, and listen if any strange noise on wather hose output. it requires a some handwork. is several metalic covers it needs to be opened.
post for extra indications
Jan 29, 2010 | Dishwashers
Washer does not stay full of water
but is the end of the hose fitting snug in standpipe?? if it is water may be siphoning out due to no air break once 1st drain takes place ..stand pipe needs to be slightly larger tah end of drain hose to allow air to break the siphoning action
Aug 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leak fromwasher during drain cykle
Removing the front panel:
1. Disconnect the washer from the electrical supply
and release the console.
2. Releasethe bellows fromthe front panel and remove
the (2) screws holding the door safety switch
assembly to the front panel.
3. On select models, disconnect the wires from the
light switch.
4. Raise the front of the washer and remove the (4)
screws securing the front panel to the washer base.
Feb 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Drain
Don't buy this brand anymore, and be sure all your friends know not to also. I have a GE, GSD4000J, it is less than 2 years old, I have used it maybe at most 6 times. Now it will not drain, washes with the same water, does a terrible job of washing. I own a remodeling service, I will never buy GE products for any of my jobs from this day forward. Have not been able to get any help from GE, they don't seem to stand behind their products at all, or care about their customers once you have bought their products.
Oct 30, 2007 | Dishwashers
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
