Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
Need to replace the ballast on a 52HM94
Changing the bulb does not fix my problem with turning on the television. After eight attempts to turn on, the red and green lights flash together and eventually turn solid.
Please provide detailed instructions for changing the ballast. Visual aids would be greatly appreciated.
  • jmallen Jul 18, 2009
    I removed the two screws on the plug that the ballast plugs into, but I can't figure out how to get to the ballast. The metal plate holding the plug comes loose, but I can't move it out of the way.
  • 147 Answers
The ballast is a small rectangular board.it is very easy to change.remove the lamp and you
will see a plug where the lamp plugs into.remove the two screws on that plug.then
remove the 4 screws holding the ballast in.remove the ballast and install the new one.
Posted on Jul 17, 2009
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
I have a Samsung HLP4663wx xaa that I just replaced the color wheel to fix the buzzing noise and then had to replace the lamp after 16541 hours so definately got my moneys worth. Had to remove the jumper...
I would assume you need to replace that ballast. Usually the bulbs out live the bulb's ballast (from previous experience)...I've seen DLPS do this type of thing when the bulbs are slow to turn on due to a new ballast being needed.
Thanks and hope it helps!
Jul 07, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Purchased a new bulb for our Samsung HL-T4675SX DLP TV in October. Less than 3 weeks after the bulb was installed, the TV would not turn on and the three indicator lights on the front of the TV came on,...
ballast failures are not that common in general. i would suspect the color wheel before the ballast. do you hear a whirring noise when the tv is trying to turn on. sometimes the color wheel will not spin correctly and the tv will not start as a result.
Dec 23, 2010 | Samsung HL-T4675S Television
My Toshiba 62HM84 won't start. I replaced the bulb and it still won't start. I replaced the ballast and the most I got was 1 second of light then off. The TV tries to start but still won't. Any...
I HAD THE PROBLEM OF BULB NOT TURNING ON. SOME PEOPLE SUGGESTED TO GET THE BULB CHECKED WHICH WAS ALRIGHT, SOME SUGGESTED TO CHANGE THE BALLAST WHICH WAS SMART BUT THERE WAS NO WAY TO CHECK IT OTHER THAN PUTTING A NEW ONE AND TESTING IT. I CALLED THE TECHNICIAN AND HE CHANGED IT BUT STILL NO PICTURE AND SAME CODE OF BULB NOT WORKING. THEN HE CHECKED FUSE ON POWER SUPPLY RIGHT NEXT TO WIRES BRINGING POWER SUPPLY TO BALLAST BUT IT SEEMED OK. HE DECIDED TO CHANGE IT TO SEE IF THIS FIXES THE PROBLEM AND WE CHANGED IT. WE TURNED ON THE TV AND WALLAH. SUGGESTION IS TO CHECK EVERYTHING BEFORE SPENDING MONEY ON NEW BALLAST OR BULB. 2 CENTS OF ADVICE, IT IS SOMETIMES WORTH TO BRING SOMEBODY WHO KNOWS WHAT HE/SHE IS DOING.
Aug 22, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
I changed the bulb of my Samsung tv and it is still blinking lamp. How do I fix it?
U here a alot of clikcking,turn power on to tv?Yes,than the Ballast board also dead,need it be replacing.The Ballast board,help to ignite the bulb.
Jun 20, 2010 | Samsung HCM4215W 42" Rear Projection...
I need to replace the lamp on my hitachi. should i also replace the ballast. thank you
For normal bulb replacement, there should be no need in replacing the ballast. Just be sure to put everything back like it was after changing the bulb. There are interlock switches that must be right for the set to come on. Thanks for using fixya.
Jan 14, 2010 | Hitachi 50UX57B 50" Rear Projection...
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Buzzing sound, resets 8 times, and then turns off. Bulb replaced
Actually ballasts run between 60-80 dlls. It does sound like you doi have a ballast issue, everytime a TV resets the ballast is the issue. Go to discountdashmerchantdotcom you'll see the ballast prices. Plus they also have free troublehsoot.
Aug 25, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Not coming on, lights blink, but nothing happens
First thing to check is the bulb. On the back of the set is a hatch with four black screws. There is a TT symbol on that hatch, open it and you'll see the black lamp housing over the ballast circuit board. Remove the silver screw on the left of the housing and pull the aparatus straight out. It may stick a little, don't be afraid to give it a tug or two. Check the bulb, the part of the filament that burns is inside the glass tube that is near the base of the bulb bowl. If it looks broken or burned. Replace the bulb. Ebay sells them for about $100 or less. I've never had a problem with OSRAM vs Phillps, so whichever. Phillips is better but OSRAM does work too.
Sometimes you buy the bulb with the housing sometimes not. Its pretty easy to replace the bulb. You-tube it. Reverse the dismantle and see if it comes on. If not, we move onto the color wheel and ballast. Email me if this doesn't fix your problem and I'll help you move onto the next step. cfoley@hawaii.rr.com
Good luck.
Apr 20, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
No Picture
its probably the ballast that is bad, call Optoma and you can buy a ballast for it, but you will probably want to have a pro do it, changing the ballast is a lot more involved than just changing the bulb, the ballast is what powers the bulb and it does go out on occasion.
Oct 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
696 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
