Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 at at startup and rinse cycle.
I bought the machine in October 2006. I called the company about this problem on July 14th.. After a bit of explaining, they agreed to send a technician to verify the problem at no cost to me. The technician arrived on the 16th of July and replaced the control module in about 20 minutes. Machine works fine.
I was also told by whirlpool to press the pause/stop button twice in order to reset the machine. While this helped a little it did not completely eliminate the problem.
I am relieved by whirlpool's respone to this problem considering I have purchased 2f ridges, a washer,a dryer and an electric range from them.
Philip
  • Philip Niro Jul 17, 2009
    Re above...July 14, 2009
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(&^$%
Posted on Sep 21, 2010
In what month and year is Mad Men set?
Season 1 opens in March 1960 and finishes Thanksgiving Day, 24th November 1960. Season 2 picks up on Valentine's Day, 14th February 1962 and ends in October 1962 with the peaceful resolution of the Cuban missile crisis. Season 3 starts somewhere during Spring 1963 with Betty Draper (January Jones) being approximately six months pregnant and ends on the evening of 16th December 1963. Season 4 begins around Thanksgiving in November 1964 and ends in October 1965. Season 5 begins on Memorial Day weekend in May 1966 and ends in March 1967. Season 6 begins at Christmastime in December 1967 and ends on Thanksgiving Day, 28th November 1968. Season 7 begins in January 1969, around the inauguration of President Richard Nixon and ends mid-season on the morning of 22nd July 1969, two days after the successful moon landing of Apollo 11.
Sep 04, 2016 | Mad Men (2007)
Oasis 110.273 "F1" error on inital and rinse cycle fill. Have already checked to make sure all connections were secure.
The F1 error on the Oasis is a known issue. Sears recalled the computer module because it's defective and produces this error along with F71 code errors. Unfortunately, unless your serial number meets their current criteria, they won't honor the recall because it expired on 08/31/2009 for some serial numbers. Best bet is to call and find out if they'll honor it. If you talk nice & originally bought it from Sears, they might. They did for me. But then we had to replace the RPS. Now the stator. This machine is an expensive piece of junk.
Nov 23, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F1 error
there is a factory defect in the control circuit board of this washer, read and call the number. post is from another owner.
I called 800-659-7026, which seems to be a 3rd party "recall" center for appliance companies, for my F1 error code. All Kenmore HE Elite Oasis machines with Serial Numbers beginning with CS48-CT49 are in the process of being recalled; however the mailings haven't gone out to customers due to hold-ups in legal with wording. Machines with these serial numbers require an upgraded control board and it takes about 10 business days for the part to come in. They ordered it with no questions asked and are coming out July 14th to replace it free-of-charge
Jul 15, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I get error F1 every time I start and before the rinse cycle. I will change cycles, change settings within cycle menus, it tales at least three attempts of shutting it off and restarting it. Now it will...
here's the part # W10189966. I guess whirlpool had a recall on the units and revised the control boards. might want to call whirlpool on that. Good luck :)
Jul 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My rinse cycle its not working
I believe that you have a bad connection or the switch is faulty. I might need replacing and it its under warranty you should call the company where you bought it.
Mar 13, 2009 | Washing Machines
F1 Alarm @ rinse cycle
F1 code = Primary Control Failure. Replace the machine/motor control assembly. If you use a screw driver in front of the machine to open the top you will find a repair manual on the inside of the front panel. or depending on the model, you can even unscrew the bottom and find the manual.The manual inside is actually meant for technicians.It contains the error codes and instructions related to them.will be looking forward for your comments if there is any further problem in this.
Dec 15, 2008 | Whirlpool Washing Machines
Brand new Front Loader not washing
well if its spinning and not washing, that does sound like aproblem with unit and not what your doing, id call a service company to figure it out, thats why you bought new, not so youd repair it
Mar 29, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal De
