Question about Northstar 6000I GPS Receiver
A wire going to one of the LED backlights chafed through and grounded to the inside of the case. I replaced the light with one from a unit that had water damage. I also replaced the inverter with a new one. The screen is working but is very dark. With an external light on the screen you can the self test and all comes up o.k. I don't know how to test the backlights.
  • jdsmart12 Jul 17, 2009
    There doesn't seem to be any power going into the inverter.
  • 3,037 Answers
Test first to make sure there is voltage going to the backlight. Use a voltmeter and let me know what you find. It could be burnt out or its inverter is bad.
Benjamin
Posted on Jul 17, 2009
  • Benjamin Patri
    Benjamin Patri Jul 17, 2009
    Then basically, you need to follow the wires from it back to the power supply. Not so simple but somewhere you are losing that voltage and I can't really be too much more help on this part. You are on your own for finding the break in the power supply to it whatever the problem may be.Once you find the problem, hopefully it will be a quick rewiring job.
Hisense 50h5g model the backlights are blinking the pictures is really dark but sound quality is still good what may be the issue
Perhaps the backlight LED driver board needs to re-seated.
Also check flex wire connectors for loose connection.
reseat or replace
Aug 16, 2016 | Hisense Televison & Video
Honey well Weather station te657w display backlight led becomes very weak, just wondering how to open the main unit to have the LED replaced with brighter ones
The problem might be very hard to repair if those led lights are SMT (surface mount technology) those diodes could be as small as this print. The case may be compression fit.
May 25, 2016 | Televison & Video
How do I clear po449 code
Check your fuses, there may be a fuse that powers the vent solenoid. Check for a rubbed-through or chafed wiring harness. Check both wires to see if they are shorted to each other, to ground or power. Visually inspect the vent valve for cracks or damage. Trace the wires to and from the PCM/EMC/ECM and check for continuity continuity using a digital volt ohm meter (DVOM). If you have access to an advanced level scan tool, actuate the valve while reading power and ground at the connector or by simply using a bulb wired to both terminals, it will light up if power and ground are OK. Using a DVOM, check the resistance of the vent, in most cases the resistance reading should be low, refer to the manufacturer's specification or compare it to a new one. Too high or low a value indicates a faulty coil inside the valve, thusly meaning replacement is necessary
Jan 31, 2015 | Cars & Trucks
Engine light bulb
Ford Dealers and repair facilities do not repair circuit boards they replace them. Ford really does not provide a way to test circuit boards. If it is a LED it would be very rare that it is defective. The circuit or the processor that turn the light on would be suspect. A pin out test of the circuit would be the first step this would include checking the wire for continuity from the board back to the processor 5 ohms or less is the standard. When in KOEO (key on engine off) mode power is sent to one side of the led the processer is powered up and supplies a ground to the other side of the LED.
The pin out test confirms a connection. I would suspect first a chafed/broken wire. Look close to the processer out follow the wires where they turn look close on the inside of the turns where they are close to other objects.
Apr 14, 2014 | 2002 Ford Escape
Back light sometimes works
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 10, 2012 | Acer Aspire As5250-0327 320gb - Perfect...
I need a replacement screen and i'm not sure which cffl/backlight to order
Here are the eBay search results for your exact system model -
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L355D-S7809+screen&_sacat=0
Sep 20, 2012 | Toshiba Satellite L355D-S7809 NoteBook AMD...
My new flashlight wont stay on
Flashlights of this type are notorious for poor design. I had one where the contact spring at the top broke its connection. Others break the ground wire when the top is unscrewed. Another design flaw is trying to solder a ground connection to the anodized aluminum case - doesn't work. I am replacing the broken ground wires with longer, more flexible ones but that's not a permanent solution. Some LED board case grounds have been repaired by scraping the solder-to-case joint although in one case I had to replace the joint by wedging in a piece of bare copper wire. Hope these tips help.
Jun 09, 2017 | Energizer Camping, Backpacking & Hiking
I have purchased a Thermaltake V3 black case and am trying to install my M2N68-LA motherboard. The motherboard has a combined 9 pin header for power switch, power l.e.d. and hdd l.e.d. which was one plug...
1) The 9-pin header you are referring to, is the Front Panel header.
(Processor to the top, Ram Memory slots to the right, the Front Panel header is at the bottom right corner on the motherboard)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00906129&lc=en&cc=de&dlc=&product=3397528
The plastic piece on the front of your computer is the Front Panel.
(Sometimes referred to as a Bezel)
Make a drawing, and notes as to where the individual wires go from that Front Panel header plug, (One-piece plug), to the Front Panel.
Follow the wires from the plug to the Front Panel.
Mark down where Each wire goes.
You may have to take components off of the Front Panel, in order to see exactly where Each wire goes.
For example:
You may have to remove the Power On button/switch assembly from the Front Panel.
It may have the Power On LED light, Power On button, (Switch), and perhaps the HarDDrive LED activity light, in this assembly.
The wires are color coded.
Generally, but not always, when two wires are used in conjunction with each other, (Example, Power On switch, or Power On LED light), the wires will be twisted together.
One wires insulation may be of a solid color, and the other wire may be white, with a stripe in the color of the solid wire.
Example: Wire with Red color, and wire twisted with it may be White, with a Red stripe.
See if these two wires go to the Power On switch.
End of example.
Follow each twisted pair of wires back down to the Front Panel header plug.
(One-piece plug)
See which socket holes the individual wires go to.
Mark it down in your drawing, and notes.
Mark where the individual socket holes plug onto each pin, in that Front Panel header. (9-pin header)
When you are finished, you will have a pinout for the Front Panel header on the Asus M2N68-LA motherboard, and will know where the individual wires go from your ThermalTake V3 computer case.
For the LED lights there is a Positive pin, ( + ), and a Ground pin. (Power On LED, and Harddrive activity LED, for example)
(Ground. Also referred to as the Negative pin. ( - )
This is DC Voltage)
If you have the polarity backwards, (Positive wire of the LED light is going to the Ground pin, Ground wire of the LED light is going to the Positive pin), the LED light will be dim.
(When operating)
Switch the wires around.
If you have questions, or need clarification of what I have stated above, simply state in a Comment.
(Believe upper right of your page)
Jul 01, 2010 | ASUS Computers & Internet
ST3S Gauge Backlight
The light should be an LED so, yes, it should last longer than that! You probably have a corroded contact inside the unit from condensation.
Nov 10, 2008 | 2007 Ducati ST3
Northstar 6000I GPS Receiver Logo
Top Northstar GPS Experts
Jose Ma DM.
Jose Ma DM.
Are you a Northstar GPS Expert? Answer questions, earn points and help others
