Question about Black & Decker VPX Drill/Driver
Has no power barly drills gets stuck when drilleig
  • 3 Answers
It appears that the carbon brushes are not making a good contact with the armature or they are badly worn
Posted on Jul 25, 2009
Can anyone tell me how to use a digging bar?
Watch this short and simple video on youtube. it explains how to use a digging bar;
Good Luck
http://www.youtube.com/watch?v=xjW9qyg_rPY
Dec 26, 2013 | Garden
My 1199vsr is not getting power
check motor brush maybe stuck in dirt
or power cord conductor cut
Nov 20, 2012 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
Chuck on my drill is stuck open and I cannot close it to put in a new bit
If the chuck is stuck open and you cant "muscle" it closed something is probably jammed up in there and it needs to be replaced. Chucks take a good share of the abuse on power tools and most manufactuers consider them a "common wear item" like brake pads or Tires on your car. A chuck is fairly simple to replace if your drill stuck open and they are commonly replaced on the higher end "Industrial Grade" Power Tools like DeWalt and Milwaukee.
Looking at the Make and Model of your drill it would probably be easiest and most cost effective to just replace the entire drill. If you tried to replace the chuck and found a chuck that will fit your tool it may cost you anywhere from $25 - $40. For Around $40 you can purchase a new drill with a fresh battery.
Oct 09, 2010 | Black & Decker CD9600SBGB 9.6 Volt Drill...
The trigger gets stuck on and needs to adjusted to turn off
Give it a good squirt of WD40 and operate the trigger a couple of dozen times after removing the battery.
Paul
Sep 18, 2010 | Powerglide Power Glide Cordless Drill
I have an 18 volt hammer drill combo drill. I
Do the same in reverse, if possible. Also, you could use two channel locks as most of those chucks have two rings, the narrow one towards the drill itself being attached to the motor. However, make sure the screw inside the chuck is tight first -- I've seen those back out and block chucks open.
Mar 06, 2010 | Dewalt 18 Volt Compact Drill Kit
DW984 Chuck problem
WD-40 works well on most power tools for freeing up stuck parts without damaging the drill. It's also good for displacing any water that may have gotten in it.
Dec 11, 2009 | Dewalt 18 Volt Compact Drill Kit
My rattle gun 18V LXT Impact Driver BTD141 has a double ended Philips stuck in it? how do i get it out?
There are a couple of ways to try to free the bit from the drill chuck. But slow and steady is the key, don't hit anything too hard, so as to not damage the chuck in the process, nor break off the bit in the chuck.
You'll need to put the bit into a bench vise and reverse the drill slowly and carefully. Make sure the bit is tightly secured in the vise and that the drill won't spin your hand around and slam it into the bench when you pull the trigger.
As a last resort, you can try tapping the bit sideways, to get it loose. With chuck opened up all the way possible, gently tap the bit sideways. This should also free the bit, but be very careful not to snap the bit off in the chuck, or you'll have a worse situation trying to get a broken bit out of the chuck.
If none of these work, you can attempt to secure the stuck bit in the bench vise and try to tap the drill chuck using a hammer and a flat brass bar resting against the drill chuck, so you don't damage the chuck. Just tap the brass bar to drive the chuck free of the stuck bit. You have to watch the bit in the vise to make certain it's not slipping and that the chuck is getting free.
Hope you find this Very Helful and best regards!
Jul 12, 2009 | Drills
Can't get the plug out to clean hair in drain
Get the new part first and do what you need to do .
Jun 29, 2009 | American Standard Cambridge 5' Americast...
Makita 6222D hole drill bit is stuck
When this happened to me I held the shaft of the drill bit tightly with my hand and reversed the direction of drive for an instant. It released at that point. It still does that occassionally though.
Jan 27, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Black & Decker VPX Drill/Driver  Logo
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
