Question about Sub-Zero 30.1 cu. ft. Cabinet Depth Side-by-Side Refrigerator 632 / F
HOW MUCH FREON AND WHAT KIND DOES MY 10 YEAR OLD SUB ZERO USE
    Champion:
  • 363 Answers
I think that you need a licenced refrigeration person to charge your system.
Posted on Jul 19, 2009
My Sub Zero 642 is freezing my fruits and vegetables. I have not changed the temperature settings. What's up? I did unplug the unit to reset it but it keeps having the same problem.
Usually a bad thermostat, but it can be a freon system problem, or a problem with your evaporator fan motor. These are problems that a good Sub Zero technician needs to repair, especially if you have a system problem, since a system problem is under a 6 to 12 year warrantee. Make sure that the company you call is a Sub-Zero warrantee company. Good Luck, Appliance Specialists
Jan 19, 2010 | Sub-Zero 642
Refrigerator not cooling top shelf
it sounds as though you have a fridge that is low on freon. If the ice is appearing mostly to the left, then thats surely your problem. if it goes all the way across, you may have a bad evaporater fan motor, fan motor switch, bad cold control, or just a door that isn't closing or sealing properly. If its the ice mostly to the left side, it probably means your evaporater is leaking the freon. I am assuming you have a model that has a cold control on the back wall, not the electronic display by your description. If your unit is less than 12 years old by the installation date, the part will still be under warranty (sub zero has an unmatched 12 year sealed system parts warranty) but the labor and freon will not be. The repalcement of that evaporater in my area usually runs about $450 with labor, freon and trip all together. It is a repair you cannot do unless you have an acetlyn torch and some silver-soldering/ brazing ability. If your model is in fact the newer style with the electronic temp display, call sub zero up (the # is on the model/serial tag in the door jamb) and tell them wahts going on. If it is in fact an evaporater leaking on this style, they will most likely pay the bill for you even if its well out of the 5 year full warranty. If you want to know for sure, remove all the shelves, then remove the cover over the lights. Then if its electronic remove the 3 screws holding the top of the back panel and tilt the panel out to you and pull it up and out: if its a dial type, remove the 2 screws holding the fan cover and then tilt the back wall out to you and lift it up and outwards, but not too far as it wil pull the wires of that control knob (cold Control) Look at the coils back there and see if the coils are frosty. If they are only frosty on the upper left of the coil, its low on freon and needs an evaporater. if its frosty all the way across, top to bottom, you need a cold control, or possibly a fan or fan switch. Hopefuly you can wade through all this. Just post back if you have any questions. Good Luck!
Aug 13, 2007 | Sub-Zero 632 / S
The compressor is working but there is no cooling at the freezer section and lower portion of the no frost GE refrigerator. I checked the evaporator coil and there is no frost. What could be the problem?
First make sure your condensor fan motor is running and your condensor is clean. If this is ok and If the compressor is running, and you have no cooling at the evaporator, you have a freon system problem. This means that you have a bad compressor, freon leak, or a freon system restriction. If the refer is under 5 years old, it usually has a 5 year system warrantee that covers everything, parts and labor. Some brands have longer warrantees, Sub-Zero has a 6 to 12 year warrantee. If your refrigerator does not have a warrantee on it, it is not worth repairing. In Seattle Washington , this repair is usually 900 to 1100.00 and we don't recommend it unless it is a very expensive refrigerator such as the 8000 to 12000.00 Sub Zeros. Good Luck, Appliance Specialists
Dec 31, 2009 | Refrigerators
I have a Sub Zero 201 F, that ices up around the freon line.
It sounds like your fridge has had some servicing done on it and has been over charged with freon and needs to be decanterred.Kind Regards.
Jul 09, 2009 | Sub-Zero 650 / O Bottom Freezer...
8 year old Sub-Zero model 690. Condensor coil leaking
When copper and aluminum are connected it cannot be welded, it has to be crimped. this is a problem that is not exclusive to sub zero, an all aluminum evaporator ( if it is in the refrigerator it's an evaporator) should resolve the problem nicely
Jun 17, 2009 | Sub-Zero 690 Side by Side Refrigerator
Refrige is 48 and freezer is 0 model 532
Fixing Freon Leak by replacing evaporator coil on Sub Zero refrigerator
May 19, 2009 | Sub-Zero 642
Ice is forming inside the refrigerator
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero 511 Freon Leak
replacing leaking evaporator on Sub Zero R134A
Jun 22, 2008 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub-Zero not cooling properly
found leak at evaporator, made a video how to replace it on Sub Zero Vacuum Condenser Light stayed on
Jun 16, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero side by side
evaporator leaks freon, made a video on how to replace it
Oct 09, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
239 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
