Question about Goldstar Dehumidifiers
Purchased June 2006 from WalMart and used 3 months a year. Now overheats and smells of burning mat'l. Filter and coils are clean. Am throwing out and never buy a Goldstar product again
I threw the dehumidifier out and vowed to never buy a Goldstar product again.
Posted on Jul 18, 2009
It is three and a half years old and ices up even at warm temps.
The problem you're having is generally caused by the air intake filter needing to be removed and cleaned and/or the cooling coils need to be cleaned.
I assume you already know how to remove and clean the filter, since you've had the unit for 3 1/2 years, so I won't bore you by addressing that.
The coils can be cleaned with warm water and a mild dish washing detergent using a sponge or rag. Once they have been wiped down, rinsed and dried, apply a light coating of WD40 to the coils.
Hope this helped you & thanks for choosing FixYa.
Sep 19, 2011 | Kenmore 54701 Dehumidifier
Our dehumidifier was working sporadically, now it does not work at all. Is there a filter to clean or a way to reboot it?
Filter should be clipped to the back. Remove it and wash it under the kitchen tap.
Reboot it?
The filter should have little to do with the mechanical function of the device ... unless it was clogged so badly that air could not circulate through the coils in the rear. This will be evident if it is the case. If so, it will look like you took the lint our of your dryer for a week or more and put it onto the coils and then wet them. The clog will be a dirty, wet 'mat'. If this is the case, you probably burned up the device. You can try to clean it by taking the device out side and washing the coils with a hose.
Thanks for your question @ FixYa.com
Aug 04, 2011 | Kenmore Dehumidifiers
My basement dehumidifier runs but extracts no water from the air. It worked when I first turned it on in June but I only emptied it once. In the past I emptied it every day in the summer. Do I need a...
Gayle, your unit has some age on it, but it may still be salvageable .
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. Or set to Maximum if yours
is a manually controlled unit.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. As far as repairs are concerned: The unit is 14 - 16 years old and the cost to repair, may be as much (or close to it) as purchasing a new unit. If you decide to purchase a new unit, be sure it's a "Low Temperature" model, as yours is being used primarily in a basement application.
I hope I have helped you and thanks for choosing FixYa.
Jul 24, 2011 | Whirlpool Dehumidifiers
The coil keeps iceing up
is the filter and coil clean? In high humidity the unit mat run too long and freeze. Try turning the humidistat a little lower
Aug 21, 2010 | Oasis Dehumidifiers
Amcor dehumidifier motor running very slowly
Hello Filter neglect is a popular cause of problems.20yrs you got your moneys worth the unit dosent owe you a thing.Burning smells sounds dangerous.Please look into replacement.
Mar 31, 2010 | Dehumidifiers
Burning smell from dehumidifer
Well is your filter clean!!!! is it over working it 30 pint 400sqft 50 pint 1000sqft 65 pint 1300 sqft. hope this helps.
Jul 19, 2009 | Whirlpool AD25BSR Dehumidifier
LG dehumidifier developing ice
First you would need to clean the filter. LG recommends cleaning the filter every 2 weeks on their dehumidifiers. The second thing you need to do is clean the coils periodically. On this dehumidifier it should include a brush for cleaning the coils. It is located on the top of the bucket. To access the coils the following needs to be done:
1.) Unplug the unit from power
2.) Remove the bucket and also the air filter
3.) Remove the front pannel by removing the 2 lower screws and depressing the tabs.
4.) Once the panel is removed you will see the coils. You need to clean them with the brush. Go in an up and down motion to remove the dirt and dust.
Now use the reverse steps to put it back together. If your dehumidifier runs often I recommend you clean the coils about every 3 to 4 months. This is a common problem on alot of dehumidifiers and people think their dehumidifier is broken. Most of the time the coils are just dirty which causes the water to stay between them and freeze. Keep me posted. Also if you found this response helpful, please rate this solution when you get a chance. Thanks - Tech101
Jul 01, 2008 | LG Goldstar LD65EL Dehumidifier
ON-LINE REGISTER FOR 2 EXTRA MONTHS WARRENTY- HOW?
I purchase a compact bar fridge from Walmart and am trying to register it on - line
Jun 29, 2008 | Dehumidifiers
Does not collect water
ok Carmo
first remove the back of the unit and turn it on. it sounds like the fan motor may not be working.there by making the dehum get hot. make sure your filter and coils are cleaned. you may need a new motor. if so buy a new motor and fan blade.be careful with the 5/16th nut holding the fan blade. the blade might look good but you have to check the hole where it rides on the motor shaft. if you into the hole it should look like the letter "D" because the motor shat is shaped that way.---good luck
Nov 11, 2007 | Kenmore 54501 Dehumidifier
Runs for a couple of minutes and then stops
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Apr 23, 2007 | Kenmore 54351 Dehumidifier
Dehumidifiers Logo
87 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
