Question about Kodak EasyShare C643 Digital Camera
Blurred pictures Samsung L77
I'm getting blurred shots even with the flash on. I can only find two settings for the flash and I'm using the one with the "eye" symbol. Granted I'm still learning this camera but the user manual is pretty bad. Having trouble getting around the menu. To make matters more puzzling sometimes I don't get a blur or at least it isn't too bad which leads me to beleive it's camera movement. But with the flash this should not happen. And I thought the shutter speed was auto.
  • Dennis Woloch Nov 20, 2007
    Thanks, I appreciate it.
  • 34 Answers
Try placing the camera on a stable surface, ie a table and taking a picture
try also cleaning the lens with a soft cloth
hope this helps
Posted on Nov 19, 2007
The pictures are blurred, with somewhat stripes? even when transferred to computer, the pictures are blurred. why is this?
clean battery and sd card contacts, usually helps, light sensor may be shot, does it do it with flash too?
Mar 27, 2015 | Samsung Es70 Silver
DSC T90 digital cam While taking pictures of any small movement, the picture blurs or shakes. Please give me solution to fix this problem
To remove the blur from photos, you need to be in a place where there is enough light to have a fast shutter speed. Using the camera indoors without the flash on will usually result in blurry photos.
Try using the flash.
Holding the camera with two hands or even better, on a tripod, will help too.
Happy shooting!
Mar 06, 2011 | Sony Cyber-shot DSC-T90 Digital Camera
My sanyo vpc-s670r digital camera has a blurred shot. how can i fix this problem? i also clean the lens still blurred especially when shotting outdoor.
You must take pictures gently. Blur picture may occur if you move during capturing a picture. Or your hand move too fast after taking a picture. Try to stay still for two or three second after push the capture button.
Blur picture when shooting outdoor can be caused by too much light. Don't forget to set your camera in outdoor or panorama mode, and turn of the flash light if you think its too bright.
Hope this help and RATE please !
Jan 16, 2011 | Sanyo VPC-S670 Digital Camera
Can't take pictures in low light/no flash with my Nikon D40X
First of all you need a tripod to cut down on the movement . Next use the mode dail and select a nigt setting .
You can even use a shutter speed in Aperature Prioity .Ypu might want to use exposure comp .
This should work for you.
Apr 07, 2009 | Nikon D40x Digital Camera
Panasonic DMC-TZ3 pictures never seem crisp and clear
TZ stands for Travel Zoom, which is code for Outside View shots. The TZ is supper in good light, not so much in lower light.
In side shots need to be with 8 feet of subject so the flash can reach. Use ISO and IS mode 2 settings, especially IS(Image Stabilization) on zoomed shots where ANY camera movement becomes amplified by the ZOOM.
Lastly, camera movement and/or subject movement will add blur to a shot. Squeeze off shot, don't push it off. Try to brace your camera against another object when possible, or hold you elbows against your sides when you can't. Treat taking a pic shot like you were taking a rifle shot. Stabilize yourself when possible and gradually squeeze off the shot when possible.
When low light cannot be avoided, try the night shot setting, which will keep the shutter open longer to gather more light, but will be much more venerable to camea movement at the same time.
Dec 13, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Blurring pictures
I had the same problem. Somehow my flash was set on "SL - Keep subjects and distant backgrounds bright." When I changed the flash to "Auto", it seemed to get rid of the blurry pictures.
Dec 08, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Blurry photos that are really frustrating!
Evening & Indoors? The kit lens is really going to struggle here. Your only immediate solution is to use ISO 1600 which makes the shutter faster but adds a little noise to the pictures.
You really want to get a better lens for indoor work. If you need cheap, try the 50mm f1.8, it's a prime not a zoom, so you will need to use your feet to "zoom" but it's incredibly good for indoor / low light work.
I upgraded to a 17-55mm f2.8 IS, it was rather expensive but I have never had a blurry indoor shot since - I do also use an external Speedlite flash with it though, which also helps tremendously.
It's an expensive hobby!!
Nov 04, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Blurred pictures
I had the same problem. The solution is in the manual but it is not straight forward. You have to set steady shot to auto when the shutter button is pressed half way down. The vibration warning will still show. At this point the camera is sensing low light. The to need to make sure the flash is set to always on. The flash setting for background will not turn the vibration warning off.
Dec 10, 2007 | Sony Cyber-shot DSC-T100 Digital Camera
Having problems with the flash\ blurred and grainy images
You should not use the flash for these shots (unless you connect a powerful external flash), it won't help you at this distance. You should use the shutter priority mode and experiment with shutter speed (no flash) to get the best result - for sports action it should probably be faster than 1/100 sec. If the light is too low you may use higher ISO setting - 200 or 400 (though higher ISO will result in grainier images, it may be your only option for blur-free photos).
Sep 07, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
S2 Pro User Questions-Focus Issue
With the camera you have, noise isn't much of an issue when pushing the ISO to 400, 800 or even 1600. Try setting at ISO 400 and change it to manual mode or shutter priority and then choose a faster shutter speed. Take some test shots. If it's still blurred, increase the shutter speed and ISO to 800 and try again.
Sep 04, 2005 | Fuji FinePix S2 Pro Digital Camera
Kodak EasyShare C643 Digital Camera Logo
59 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
