Question about Brother MFC-8460N All-In-One Printer
Fax only mode and will not make copies
I don't use the fax on this machine I only want to use printer and copier. It says Fax only mode and beeps when ever I try to select copy or scan.'
    President:
  • 2,306 Answers
Press the mode switch until fax only goes off.
Posted on Jul 20, 2009
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Copy machine is stuck in the copy mode
Sounds like the machine does not have a fax board on it. Have you been able to fax in the past?
If nothing else, try rebooting the machine, then have your servicing dealer come out to check the fax board module if rebooting doesnt help.
Skelton Business Equipment Houston Copiers
Nov 18, 2013 | Sharp Mx-m260 26ppm Copier
Fax default
I found this online today:
Mode Timer
The (Brother MFC-8480 DN) machine has 3 mode keys on the control panel: Fax, Scan and Copy
You can set how much time the machine takes after the last COPY or SCAN operation to return to FAX mode. If you choose OFF, the machine will stay in the mode you last used.
1. Press MENU, 1, 1.
2. 2. Press up/down arrows to choose the amount of seconds or OFF. Press OK.
3. 3. Press STOP/EXIT. I haven't tested this yet, as the machine I'm trying to adjust is at my workplace, but maybe this answer is what we're looking for.
I
I
Nov 23, 2011 | Brother MFC-8480DN All-In-One Laser...
How to fax
connect the fax machine to the phone line and before doing a fax inform the receiver that you are going to send a fax. then select fax mode on the fax machine and there would be a beep after that the document to be faxed would go in and come out from the bottom. when connecting a fax machine better be aware that you knowfax is allowed in your telephone network..
May 13, 2011 | Office Equipment & Supplies
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Can't fax out on my Epson Stylus CX5800X
Verizon is lying to you. Fax machines are analog devices.
Mar 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Muratec F-300 is not used for faxing, but will not copy either.
Download (FREE) the operators manual from Muratecs web site.
www.muratec.com
Make sure you are in the COPY mode(not FAX.) before trying to make a copy. As the F-300 is a "fax" machine, it will probably be in the fax mode as default.
The downloaded operators manual will help.
Mar 07, 2009 | Muratec F-300 Fax
No copy and send fax from adf unit
First try reseting the unit by holding the * key and the enter button and the same time turn it on until it starts beeping. This will rest the machine. If this does not work. you need ADF rollers the can be purchased for 20 to 25 bucks
May 08, 2008 | HP LaserJet 3380 All-In-One Printer
Only Button lit is Fax
power off machine by pulling out the electrical plug.
Wait three minutes. Plug in machine to power. Wait until machine has finished its set-up.
Now you should be able to change the programms (scan/fax/copy)
Set Date and time and in case, your fax nr.
Nov 22, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-8460N All-In-One Printer Logo
2,065 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
