Question about Raymarine C80 GPS Receiver
Whenin use, my c80 emits a series of 3 loud beeps
When in use, my c80 emits a series of 3 loud beeps approximately every 30 seconds. I can't get it to stop. Any ideas?
    Problem Solver:
  • 14 Answers
You have triggered MOB (man over board) press and hold the MOB button in for 30 seconds.
Posted on Sep 23, 2009
After replacing my battery, I am unable to start the car without hitting the alarm reset under the dash. A mechanic told me to turn the key up to crank, quicfkly 5 times to reset. That did not work.
PLACE THE PROGRAMMED KEY IN THE IGNITION SWITCH. FOR THE FIRST KEY. TURN IGNITION SWITCH ON AND WAIT 3 SECONDS RETURN TO OFF POSITION AND REMOVE KEY. FIRST AND SECOND PROGRAMMED KEY OPERATIONS MUST BE PERFORMED WITH IN 15 SECONDS. INSERT SECOND PROGRAMMED KEY AND SWITCH IGNITION ON. WAIT APPROXIMATELY 10 SECONDS. ENSURE IMMOBILIZER WARNING LAMP BEGINS TO FLASH AND AN ACOUSTIC SIGNAL IS EMITTED.SWITCH IGNITION OFF AND REMOVE KEY.WITHIN 50 SECONDS INSERT NEW KEY AND SWITCH IGNITION ON.WAIT APPROXIMATELY 10 SECONDS.ENSURE ACOUSTIC SIGNAL IS EMITTED AND IMMOBILIZER WARNING LAMP REMAINS ILLUMINATED FOR 3 SECONDS INDICATING PROGRAMMING COMPLETE. FOR EACH ADDITIONAL KEY REPEAT PROCEDURE STARTING FROM THE BEGINNING.REPLACEMENT KEYS CAN ALSO BE REPROGRAMMRF USING DIAGNOSTIC EQUIPMENT.MAXIMUM 8 KEYS CAN BE REPROGRAMMED.
May 21, 2011 | 2005 Chrysler Sebring Conv
I have a barcode scanner Symbol S/N M1J82M51E. When scanning the item barcode it makes very low volume. How to increase the bipping scanning volume for the Symbol Scanner?
1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
Sep 18, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Cant display
need to find out if the issue is with the display, power chord, vga cable, vga card or the connectors...
1. disconnect all the cables from the LCD or the monitor, now just connect the power chord and power on the display and now see if it gives you any display
2. Try swapping the power chord with the tower (if its a desktop).
3. Try and change the VGA or the HDMI cable to test if the issue is with the cable or not, (the cable that usually goes from the back of the display to the tower)
If the issue is with video card then launch PSA on your Dell machine and perform LCD bist test.
To launch PSA:
1. Restart the system.
2. At the Dell logo screen, press <F12>.
Note:
Some systems do not have an F12 key, to access the boot options you have to press the <0> (zero) key at the Dell logo screen.
3. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics, then press <Enter> to begin PSA.
4. Write down any error codes listed.
Steps to perform LCD BIST after PSA is launched:
1. Watch the screen and listen for the color bar test prompt tones emitted by the PSA Diagnostics. If the screen is visible, one will see the PSA diagnostics draw a series of multi-colored bars across the screen. When completed, a prompt asking if the pattern was seen appears, accompanied by a brief series of tones.
2. Press <N> or wait approximately 30 seconds to fail the color bar test.
3. Watch for the LCD BIST color generation and listen for the beeps every 2 seconds that indicate LCD BIST is running.
LCD BIST runs for approximately 20 seconds, then stops. The 3-3-3 or 3-3-4 error code is then displayed when the LCD BIST is complete. If LCD BIST does not initialize, then the system may not have been upgraded to PSA version 3019.
May 17, 2010 | Dell (W2562) Motherboard
I want to mirror my Raymarine C80 on to a LCD monitor in Saloon, How can I do this?
You are unable to make that happen. The C80 displays are not able to be "cloned" or "mirrored". Sorry, but you would have to upgrade to the new C-Wide series or E-Wide series to complete the task.
May 02, 2010 | Raymarine C80 Multifunction Display
I have a red vertical line on my dell inspiron laptop.How do I remove it?,please
Try connecting an external monitor to the Dell Inspiron 9300and see if the vertical line is also present on the monitor. If themonitor display is fine, then your laptop’s LCD display panel isdefective. If the monitor also displays the vertical line, then yourproblem is with either the video card or motherboard located insideyour laptop.
Another answer:
run the PSA diagnostics. to do so, press and holdany non-keyboard button( like the internet hotkey or access directbutton or even the speaker mute button) and then press the power buttonand power up your system. if your inspiron doesn't have a non-kbbutton, then press the <fn> key.
release both the buttons and the diagnostics begin to run.after thediags finish. if the monitor is working fine, it'll simply say"passed". however, if it fails it would emit a few beep codes.carefully check those beep codes:
1.) if you get a 3-3-3 or a 3-3-4 error beeps, then we use the LCDbuilt in self-test (BIST). boot to PSA diagnostics again. Watch thescreen and listen for the color bar test prompt tones emitted by thePSA Diagnostics. Press <N> or wait approximately 30 seconds tofail the color bar test. The system will emit a 3-3-3 or 3-3-4 PSAerror after failing the color bar test. Wait for two iterations of thefailure code then press <Y>.
Watch for the BIST color generation and listen for the single beeps that indicate LCD BIST is running.
NOTE: Patterns of flashing color should appear on the screen. Withevery color change, an audible beep will be heard. If the patterns ofcolor do not appear, and the beeps are audible, an LCD failure may bethe issue. If the patterns of color appear, a video card or motherboardfailure may be the issue.
2.)if you get an error code apart from 3-3-3 or 3-3-4 :Ensure thesystem is powered off. Press and hold the <Fn> key and press thepower button to power the system on. Release both buttons.
The PSA diagnostics sequence begins. Make note of any alert tones or error messages.
error codes:
123- memory fails
141,142,143,144,145,146 hard drive error
147- IDE optical drive fails
148 optical drive built in test fails
122-memory test initialization test failure
111- fatal diagnostics exception.
i really hope you dont get any of these. these will help you determine,if you need to change the LCD. when you call dell, they will run youthrough these steps anyways. so if you finish them beforehand, you wontpay much to talk to them. cheerio then.
http://answers.yahoo.com/question/index?qid=20060722190406AAHejuS
Jul 30, 2009 | Dell Computers & Internet
No display lights
Run the PSA Diagnostics and Obtain the PSA Error Code
To run the PSA diagnostics and obtain the PSA error code, perform the following steps:
Shutdown the computer.
Press and hold the <Fn> key, then press and release the power button.
Release the <Fn> key when the lock lights above the keyboard begin to flash or Diagnostic boot selected is displayed in the upper right corner of the screen.
Release the <Fn> key.
After approximately 2 minutes the system produces a number of alert tones.
After the alert tones, the system produces either a series of low beeps or error codes.
Note:
PSA diagnostics will prompt for input during some tests. The resulting error message does not necessarily indicate hardware failure.
For example, input is required during the color bar test. Failure to input a response will eventually result in a timeout error: 1000-0333 Graphics test timed out waiting for keyboard response. This does not indicate a graphics failure has occurred.
Note the sequence of beeps or error codes.
Initialize LCD BIST Diagnostics
You can initialize the LCD Built-in Self Test (BIST) in two ways, depending on the revision of Pre-boot System Assessment (PSA) diagnostics:
PSA versions 3019 and greater run LCD BIST immediately after failing the color bar test, via user input of <N> or waiting for it to time out prior to generating the 3-3-3 or 3-3-4 error. PSA version 3019 became available in November 2005 on various Dell laptops. The PSA version is upgraded with the BIOS.
With older versions of PSA diagnostics prior to November 2005, LCD BIST runs after responding with a <Y> after receiving a 3-3-3 or 3-3-4 error code.
To initiate the LCD BIST on PSA versions 3019 and greater:
Boot to the PSA Diagnostics.
To initiate LCD BIST on systems with PSA versions prior to 3019:
The system emits a 3-3-3 or 3-3-4 PSA error after failing the color bar test. Wait for two iterations of the failure code and then press <Y>.
Note:
On a working LCD, the PSA diagnostics shows the following message:
Error Detected, continue testing? Yes or No or Retry.
Patterns of flashing color should appear on the screen. With every color change, an audible beep is heard. If the patterns of color do not appear, and the beeps are audible, an LCD failure may be the issue. If the patterns of color appear, a video card or motherboard failure may be the issue.
IF AN ERROR IS INDICATED, PLEASE CALL DELL SO YOU CAN SEND SYSTEM TO SERVICE DEPOT FOR REPAIR (WE'VE JUST TRIED TO ISOLATE ISSUE TO SEE IF ERROR IS CAUSED BY HARDWARE OR SOFTWARE, OR JUST SOME CONFIGURATIONS)
Thanks and Goood luck! =)
Jan 03, 2009 | Dell Inspiron 9100 Notebook
30 Seconds High Beeps with Hazzars
The battery is low which is causing the alarm to activate, replace the battery. I'm going to guess that it gets pretty hot where you are between the times you listed. BMW cars have been known to be affected by heat.
Dec 17, 2008 | 2001 BMW 5 Series
Raymarine C80 GPS Receiver Logo
549 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
