Question about Nokia N95 Cellular Phone
Nokia n95 won't hold a charge
My nokia n95 will not hold a charge for more than 6 hours, i have bought a new battery but it has made no difference so i think it may b something to do with the phone handset. When it on charge it seems to b charging fine - somebody pls help...
If you bought a new battery but it has made no difference so i think it may b something so you must repair yor mobile
Posted on Jul 17, 2009
    Problem Solver:
  • 5 Answers
Not sure if the n95 is the same as n73 for how it runs, the n73 does not have an auto keypad lock, I downloaded an application to do it.
However it flattened the battery quickly, when I removed it the battery lasts for the original time.
Have you installed something recently? if so try removing it
Posted on Jul 19, 2009
My n95-3 turns on but stops at the nokia logo and shuts down and won't charge from what i gather have new battery new charger still no go? so basiclly won't turn on only lights up to nokia logo and turns...
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:
Soft reset code *#7370#
Hard reset code *#7780#
If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
+ Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the "*" button, and the number "3? button.
+ While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Regards
Egroeg
Mar 24, 2011 | Nokia N95 Cellular Phone
When i plug the charger in my Nokia N95, the white (screen is dim) startup screen with the word "Nokia" will appear, then after about 5 seconds the screen will go black and will not charge. This has...
you bought a fake battery or the battery terminal are bad and are having poor contact with the battery.remove the battery and try to clean the three golden panels that come in contact with the battery
Sep 23, 2010 | Nokia N95 Cellular Phone
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
Sudden Battery drainage - from full charge within 14 hours
turn off bluetooth if its on because bluetooth wastes battery life on any phone.
go to Tools > Settings > Personal > Display > and change the light settings. if its on the highest light setting then that would be a major factor on why your battery is draining quickly.
hold the menu button and check if any applications are still open, close any that you don't need open.
Apr 20, 2009 | Nokia N95 Smartphone
Fitted battery to nokia n95 and the phone stopped working
the battery that u ve bought its not fits the phone battery reference:
Nokia BL-6F - Batterie Li-Ion 1200 mAh
Nov 30, 2008 | Nokia N95 Cellular Phone
My phone nokia n95 losses its battery charge every 3-4 hours
Its time to replace the battery. Also check that the charger is working properly, and the contacts on both the phone and the charger are not oxidised. If they are, try scraping the contacts gently with a sharp object like a jeweller's screwdriver , etc..
Oct 25, 2008 | Nokia N95 Cellular Phone
Nokia n95 battery
hi i had the same prob update the phone on nokia web site it should give about 6 hr battery life
Sep 28, 2008 | Nokia N95 Cellular Phone
Nokia n95 battery does not hold its charge only lasting about 12 hours on standby
I HAVE A NOKIA N95 MOBILE ANG IT WAS PURCHASED IN AUSTRAILIA BUT WHEN I USED IN INDIA THAT TIME THE BETTERY IS CHARGED ONLY 2HR AND I TRY TO CHANGE MY BATTERY BUT NO SOLUTION SO PLS TELL ME ABOUT THIS.
Aug 11, 2008 | Cell Phones
Nokia n95 fault
I was just reading about a similar problem the other day. Make sure you don't have any of the buttons locked down in the pressed position.
Specifically, they were talking about the gallery review button, next to the camera shutter button on the right side of the phone, the one with the little PLAY arrow and the checkerboard pattern on it.
Jun 10, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
613 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
