Question about Dryers
I am missing the temperature knob for my dryer Model # FGRB500DS0 where or how can I purchase a replacement?
    President:
  • 1,136 Answers
Hi, I believe the part #134844410 is the knob you are looking for. Try www.repairclinic.com
They have this in stock. You can type a model # in and make sure this is the knob in question.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 17, 2009
Where is buzzer switch located on model crer5700as1
Good Afternoon Friend,
I understand you want to know where the buzzer switch is located on your Frigidaire dryer, model# CRER5700AS1. If your particular model dryer is equipped to turn off the buzzer, the switch will be located between the temperature knob and the start button, and named "Cycle Signal". If your dryer is not equipped with this feature, then there will not be an extra knob. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire Dryers
Adjust level water knob
Hi Leslie, great question! Since the knob is missing, it would have to be replaced and then installed. According to the post above, the model number for your washer is GLWS1339EC. If that's correct, you would need part number 134034902. Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). To install the knob, align the back of the knob to the shaft and it should snap on. If for any reason you have difficulties you can use the service locator option on the manufacturer site to find a tech near you to further assist you. Thank you for allowing me to assist you.
Aug 17, 2013 | Frigidaire Gallery GLWS1339EC Top Load...
Looking for a Model Number for my dryer
Post a picture of it with the door open
Dec 27, 2012 | Dryers
Searching for Model Number for a
post a picture of the dryer with the door open
Whirlpool AWG338 - Missing temperature control knob
whirlpoolpartssurplus.com call me and i can ship one out
Jun 24, 2009 | Whirlpool AWG329 Front Load Washer/Dryer
Pulled knob off 70 series Kenmore dryer.
I just took a look at your unit. Thanks for the model number. The knob when properly functioning, simply slides down over the shaft and should fit snuggly. Take a look at the back side of your knob and see if it is cracked. If it is, part number is 3402594 and your cost is around 55.00 in new or 27.00 in good quality used. Used would be cheaper obviously. Run a search engine for good quality used parts if looking for a used one. Good Luck, Eric Campion
Mar 02, 2009 | Dryers
Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jan 08, 2009 | Frigidaire Dryers
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Dryers Logo
21 people viewed this question
Top Dryers Experts
