Question about Palm Treo 750 Smartphone
Screen not aligning I use the setup ' align screen' but it never ends. i have to tap way below my desired selection to make it work
    Problem Solver:
  • 6 Answers
Some things you can try:
1) Clean the screen with a very slightly moist cloth (or with screen cleaner if you have some), ensure the edges are free of dust or dirt.
2) A Hard or Soft Reset may also help, more info HERE
If none of these work then a new screen (ebay cheapest) may be your only option.
Posted on Jul 24, 2009
Screen not aligned
Ref. HP ipaq hx4700: "Align screen" after hard reset or battery loss. I know others have had trouble getting past the "align screen" setup; I saw a suggestion somewhere that said the points were registered incorrectly (maybe in some, but not all of this model?); and they had to tap at locations other than the center of the cross symbol. I tried a variety of combinations, and found that if I tap ABOVE the center (but still on the vertical centerline) for the middle, top left and top right locations; and tap BELOW the center (but still on the vertical centerline) for the bottom left and bottom right...it worked. That brought me to the "Stylus" setup screen...which I also became "stuck" on. So far, I haven't found a solution to THAT issue yet. Gee, why can't they make these things simpler?
Feb 13, 2012 | Computers & Internet
Align screen problem
Sep 21, 2011 | HP iPAQ HX4700 Pocket PC
Printer cartridges wont align says alignment failed and then paper too narrow
I request you to perform the steps below to align the cartridge:
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges. Recycle or discard the page.
Bypass the alignment :
Press and hold the Enter button, and then press Menu
Mar 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cannot get past the align setup.
Try pressing harder on the screen. After about 3 cycles of hard presses the align screen setup usually ends. If that doesn't work, the setup eventually does end but it may take a while.
Dec 04, 2009 | Samsung SCH-i760 Smartphone
I have an imate pda2k pocket pc and is working good. Out of curiosity i tried hard reset and it ends to align screen. Everytime i made a hard reset the screen show " tap the screen to setup your pocket pc"...
tap and hold on align target until it moves to next corner or next step, if you are using windows 6 or 6.5 you should be very much accurate on taping and holding to align the screen.
Nov 01, 2009 | i-mate PDA2k Pocket PC
The align keeps on and on
You should align your screen by tapping each time (Just tap a bit carefully and with a little bit more pressure) that cross shows up during the setup process. It should take 4-5 steps and at the end you can follow the other setup instructions. Hope this helps.
May 17, 2009 | O2 Xda II mini
Samsung sch-i730 touchscreen problem
use buttons to go to start,settings,system,screen then click align screen
Jan 17, 2009 | Samsung SCH-i730 Pocket PC
Imate pda2k pocket pc shows align screen
go to start, setup, system, screen, and then click align screen. and then it will give u some small circles to tap on it. u tap correctly on the circles. after few clicks it will automatically tell u that ur screen has been aligned. ur problem is solve by a cute pakistani. pakistan live long. love u.
Oct 06, 2008 | i-mate PDA2k Pocket PC
Cartridge alignment using vista
Option 1:- This method of aligning or cleaning ink cartridges will work for most computers and printers. Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the following steps are not the same as those you see on your computer, skip to the next option. Each option does not work on every computer.)
Click Start, then Printers and Faxes.
Click the desired printer icon to highlight it.
Click File, then Printing Preferences.
Click the Services tab.
Click Open Toolbox.
Click the desired task.
Option 2:- Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the steps below do not match what you see on your computer, skip to the next option. Each option does not work on every computer)
Click File and Properties.
Option 3:- Follow the instructions below to align (calibrate) or clean the ink cartridges:
Double-click the XXXX Printer Assistant icon on the Desktop.
Click the Utilities button or the Tools and Updates button.
Click the Printer Maintenance button.
Option 4:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
Right-click the Printer icon on the Taskbar.
Click Open Toolbox.
On the Device Services tab, click the desired task.
Option 5:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
Click Start, Programs, HP DeskJet (your printer) series vX.X, then HP DeskJet (your printer) series vX.X Toolbox.
Click the Device Services tab.
Option 6:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the steps below do not match what you see on your computer, go to one of the other options. Each option does not work on every computer)
Click Start, Programs, Hewlett-Packard, HP DeskJet XXXX series, then Printer Assistant.
Option 7:-Double-click the HP Director icon on the Desktop.
Click the Utilities option.
Jul 17, 2008 | HP DeskJet 5150 InkJet Printer
Toshiba Touch Screen does not work
Hi This may help you :: Select , Settings, System tab, Align Screen to adjust the touch screen. If the screen alignment loses calibration it may not be possible to adjust alignment using the above method. Also, here is a link that may help :: http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=http--cdgenp01csdtoshibacom-content-support-manuals-userguides-su530093-ppce400ug20030916pdf&sliceId=pdfPage_113&dialogID=6730022&stateId=1%200%206728267
Apr 30, 2007 | Toshiba e740 Pocket PC
Palm Treo 750 Smartphone Logo
235 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
