2003 Audi A6 Logo
G
Gloria donez Posted on Jun 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Audi 2003 A6 is stuck in neutral starts but don't move.
Stuck in neutral starts but don't move
Joe Ball
Level 3:
Master:
  • Master 591 Answers
  • Posted on Jun 05, 2016
Joe Ball
Master
Level 3:
Master:
Answers
591
Questions
Helped
165815
Points
1736
Is it a manual transmission or an automatic? If it's a manual (clutch pedal), then you've got a problem for the shop. If an automatic, it should shift into a forward gear or reverse whenever you depress the brake.
1999 Audi A6. The lighter fuse, which one is it?
Question edited for clarity.
Question moved from COOKING category. It got lost for 10 years!
Audi A6 / S6 (C5/4B; 1997-2004) fuses and relays
Fuse Box Diagrams https://fuse-box.info > audi > audi-a6-s6-c5-4b-1997-...
Fuse box diagrams (location and assignment of electrical fuses and relays) Audi A6 / S6 / RS6 (C5/4B; 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004).
My Audi A6 is stuck in neutral and will not budge I can start the car and everything works it just will not come out of neutral
When you say it is stuck in neutral what is stuck? is the shiftter stuck in the neutral postion or is the car not moving when shifter is placed in drive or other gears,
if the car doesnt move in gear i would say it is transmission releated, this may be a bad tranny or fluid is very low.
check your transmission oil, make sure it is full. this is were i would start,
Cd cant eject from stereo of A$ quattro 2003
Try (using an old CD) inserting another CD under the stuck CD...you may need several attempts...the eject should catch...and then release (eject) the stuck CD...Hope this helps...:)
Audi shifter stuck
theres a small button located near the shifter.press it and you will be able to move the shifter
When starting 2.4 2007 a6 triptronic,i sometimes have to move lever in and out of park to get car started only 37000 miles driven.Is this a common problem.
there is a device called a neutral safety switch. it prevents the car from starting in any position accept park or neutral. the switch is most likely defective and will have to be replaced. try starting the car in neutral. this might aleviate the problem of intermittent starting.
1helpful
Brake lights stay on all time on audi a6 2004 model
The brake switch that is located just above the brake pedal is either out of adjustment and button is stuck on and you just need to move it around and put back in place. or the switch is faulty and needs to be replaced.
IT IS STUCK IN PARK, BUT CAR DOESNT START
try putting it in neutral, if it starts your neutral safety switch is the problem
2answers
A6 2006 model stuck in park
Since it is electronically programmed, it is best to
call your nearest Audi dealer service center to have it checked. Normally, replacement parts for
this kind of defect, is sold by them.
1helpful
Hi I have an Audi A6 2.4lt Auto year 2000 my question is on the dash instruments there is a yellow triangle IE warning me something is wrong. My gear selector jamsgets stuck will not move, I had water in...
Have someone check and see if the brake lights come on when you press the brake pedal..The warning lamp may indicate a fuse out to the brake light circuit--if the fuse is blown/faulty then the gearshift won't move, it needs to "see" the brake circuit is on before allowing the shifter to engage.
2helpful
3answers
1995 Audi A6 won't go past seond gear
for Audi A6 2.8 automatic I want to ask the owner of this car if the mechanic repair the automatic gear or no after I will give the solution
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
