Question about AEG D2100-4 Electric Double Oven
How to set the time on clock - AEG D2100-4 Electric Double Oven
Clock is working but display will not stay on . Colin
Posted on Mar 30, 2011
Have not been able to set the time on clock - the actual model number cannot be found on the oven
Posted on Jul 24, 2009
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Regards,
BElectric
Dec 31, 2010 | Bosch Ovens
Setting the clock
Push the clock button,then push the up or down temperature arrows to set the clock. After it is set,push the clock button again.
Mar 22, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
How do I set the clock time on Stoves Cooker efa700h. I would assume the clock is the same on most stoves models
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
Aug 02, 2009 | Stoves 720EF Electric Double Oven
Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Nov 17, 2008 | Ovens
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
AEG D2100-4 Electric Double Oven Logo
1,082 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
