Question about Singer Sewing Machines
It either wads up or breaks - Singer Sewing Machines
  • 46 Answers
Dear Sir / Madam,
If the needle thread becomes all tangled underneath when you begin to sew there are only a few things that can be wrong.
It is not only Singer machines but most domestics as people only use them occasionally and forget how to thread them correctly.
1) Get out your threading diagram and follow it carefully.
2) Make sure that the needle thread is in between the main tension discs, if it is only running around the edge of the discs the machine will do exactly what you say.
3) Lift the presser foot up with the lever at the back of the machine, this should part the main needle thread tension discs, DO NOT TRY and dismantle the tension assembly if you are not sure what to do.
I suggest you get a bit of fabric or similar and remove any lint that is trapped between the tension disks.
I hope I have helped you, but please contact me if you need more help.
Posted on Jul 25, 2009
Husqvarna classica 105 - won't sew - thread wads up in bobbin area
this is a problem from the needle thread tension not tight enough
tighten the thread tension right up
Aug 08, 2016 | Husqvarna Sewing Machines
Keeps breaking needles
Slow down and watch what you sew over.
No needle is going to sew through the metal part of a zipper.
With many layers of fabric you have to slow down. If you have multiple layers of a thick fabric you may have to resort to using the hand wheel to get through the layers.
Another tip would be to not pull on the fabric. The machine is capable of "feeding" the fabric at the rate it requires. When sewing with many yards of fabric the weight of the fabric may create a pull on the needle. If the needle is pulled so that it no longer goes through the need plate properly it will hit the metal of the needle plate and break. Instead rest your hands on either side of the fabric and gently steer the fabric. Do not pull it out of the back of the machine or shove it into the needle. With large yardages wad up the fabric around the machine so that the weight of the fabric isn't causing strain around the needle.
One other tip. If you have a needle plate in your machine that only supports straight stiching, that is one with a needle hole that is just big enough for the needle to move up and down, and you switch to a zig-zag stitch, you will break the needle. Most factory installed needle plates have a needle hole large enough to support the largest zig-zag that the machine can support. But some machines have custom needle plates (for quilting) that only support a straight stitch.
Dec 08, 2014 | Sewing Machines
Thread keeps wadding around the metal post at the back and above of the bobbin case
Sounds like there is fuzz trapped somewhere around the bobbin or race. That often happens when you clean a machine. You may need to take the face plate off and gently remove thread or fabric that might be hung inside. Look carefully in and around the bobbin and race and gently remove any debris you find.Count to 10 and grin.
Jul 05, 2014 | White Sewing 1740 Mechanical Sewing...
Singer futura xl400 embroidery needle keeps breaking
The problem is being caused because the thickness of the material is not allowing the embroidery foot to land squarely on the fabric. The needle is then close to the back of the foot, and when a jump stitch is encountered, the needle hits the back of the foot and breaks. We used to suggest that people take a small wad of something and stick it under the presser foot lifter to raise it a little--not enough to trigger the sensor, but enough to raise the foot. However, that\'s difficult to do and keep in place on an XL machine.
However, a much better solution is to simply switch to a darning foot. Both can be used for embroidery, but the darning foot is spring loaded and starts out flat. Plus, it\'s much easier to get on, and much easier to get past the rim of the hoop when you\'re putting the hoop on.
One comes with your machine, but if it didn\'t, I have purchased several from eBay. They are VERY inexpensive, and my personal preference is one with a closed large round metal ring at the bottom. All Futuras, including yours, take a low-shank foot. They are very used by many machines and therefore very commonly available. I think you\'ll be very pleased with the results!
Apr 11, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
LOWER BOBBIN BINDING UP
Readjust the needle timing and check the thread tensions top and bottom.
Jun 09, 2013 | Kenmore Sewing Machines
I have a Bernina 1008 and I love it, but every time I try to sew with it lately, the bottom thread wads up and makes a terrible mess. It will sew OK for a little bit and then the bobbin thread sort of...
Hi, I'm guessing you have the bobbin in the bobbincase upside down and its turning the wrong way. Or the machine is not thread correctly. Possibly there is junk in between the tension discs at the top that the thread goes between. Just some thoughts.
Rick
Sep 30, 2009 | Bernina 1008
Thread wad on undersurface
machine not threaded properly? wadding thread underside means upper thread does not have tension.
Jun 30, 2009 | Brother SE-270D Computerized Sewing...
Tension
Check out this site. There is pictures of each machine there. All the Q&A answers in simple language, as well as a GREAT cust. support. (its a Brother after all!)
I found download manuals there as well.
http://welcome.solutions.brother.com/bsc/public/Model_list.aspx?reg=us&c=us&lang=en&titleid=36
I hope this helps!
Happy sewing!
Sep 30, 2008 | Brother LS-1217 Mechanical Sewing Machine
Thread wadding up
Tension!!!! Its all about the tension! I just had this issue after loosening my tension. So tighten it - the higher the number the tighter the tension. My tension is set at 6 on a Singer 9005 and it seems to work great. By turning it down to 4 I ended up with huge loops/wads of string. Hope this helps!
Nov 03, 2007 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
89 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
