Question about HP Photosmart C6180 All-In-One InkJet Printer
I have a HP photosmart C6180 and for over a year, I can only print color. My black ink makes a smudge so badly it's unreadable. I've done all the fix it suggestions and it doesn't fix it. What should I do?
  • HP Master
  • 13,433 Answers
If the instructions below don't help at all, the printhead may need to be replaced, in that case it would be best to contact hp or your dealer for repair service.
Have you done 2-4 head cleanings and then looked again if it improved?
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Run all the cleanings atleast two times and try printing again. If you have a option there to only clean the black cartridge use it instead of cleaning all the cartridges since black is the only problem.
Also aling the cartridges ones your done cleaning.
Posted on Jul 17, 2009
Put in all new ink. Black ink blobs all over paper when I tried to print. Printing very light almost unreadable.
remove and reinstall the cartridge/s to ensure that they have been installed correctly before buying a new printer
May 07, 2016 | HP Photosmart C6180 All-In-One InkJet...
Black ink will not print on Photosmart C6150; Ink
I'd do the reboot of the printer.Turn it off,unplug for 60 seconds,plug it back in,turn it back on and see if the black will work.After plugging back in it should clean the print head and then you can do a test page to make sure.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00728224&cc=th&lc=en&dlc=en&product=1153494
This site will show you how to print a test page.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer leaking and not printing all colors
Your printer uses a seperate printhead that is connected to the ink wells (cartridges) with long thin tubes. If the printer is leaking ink the issue will be either with the printhead or the lines connecting to it. With this type of printer though, either way the printer cannot be repaired and you are looking at replacing.
You can always call hp too though. At 1.5 yrs your printer will be out of warantee but they can offer specials on refurbished printers. Sometimes up to 50% off or more so always worth a call. I personally have have a printer that I have upgraded from and it arrived in new condition and still comes with 1 year warranty.
Jan 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 Will not print in black.
Strangely enough, I have an Epson multi-use that has done the same thing to me. The boys at the shop said they had to practically replace the printer heads, but I got it home and it still did the same thing, so I'm inferring from this that it's a problem that wasn't forseen by the printer gods when they invented this contraption. I'm guessing somehow that it's not the black ink head that's bad, but probably the frame that holds it is bent or misaligned, and the printer lackeys are hiding this bit of evidence from the gods to avoid the shame, as I could never get a straight answer from any of them. Good luck.
Aug 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
Black ink cartridge wont print, have installed a new ink refill still no joy. Will print in all other colours.
Well if you already installed a new black ink cartridge and still wont print, then try cleaning your printer head. It can be that the some ink was hardened and got stuck preventing you to print a black color.
Jul 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
May 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
HP Photosmart C6180 colors no good - missing colors & muted. No longer aligns print when requested, per HP note at end. Already cleaned print heads,[OK], aligned printer numerous times-doesn't work....
try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Won't print black ink
I am on my second Photosmart C6180, the first one I had quit printing black ink after 6 months, after hours with the HP help desk, the finally decided to replace the printer. I have now been using the replacement for several months and just this weekend it too quit printing black ink...no copying, no printing and no faxing.  I am now shopping for another, not a HP.
Sep 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
