Question about Samsung 2008 M600 Unlocked Watch and Mobile Phone
Seadoo gti se 130 - replace rear bumper
Looking for instructions on how to replace rear bumper on 2008 seadoo gti se 130. Thanks.
Do I require any special tools to replace the driver's side rear reflector on the bumper of a 2008 Hyundai Vera Cruz. It appears to snap in, but I don't want to break it. Thanks.
There's nothing in the manuals about special tools. I have the same problem. I think you'll have to remove the lower bumper in order to get good access to it. It appears that there is a black housing screwed into the bumper from the rear side and the lens would snap into that.
Apr 23, 2015 | 2008 Hyundai Veracruz
2008 ford escape. removal of rear bumper cover
Pop the Hatchback open and remove the connectors
from the top of the bumper cover.
Optional Step: Using a Floor Jack, raise both sides
of the car in the back, supporting both sides with
jack stands, and remove the rear wheels.
Using Torx Bits, remove the inner rear wheel well
lining.
Get behind the rear wheel well and loosen the bolts
holding the bumper brackets on. They're pretty
difficult to find and remove. Be Patient. Do the
same to the other side.
Remove the rear bumper cover by pulling the cover
outward from the part nearest the wheel on both
sides. Once removed, take off the 2 black mounting
brackets from the bumper cover.
Good Luck
Feb 27, 2015 | 2008 Ford Escape
Po544 fault code
po544 code is exhaust gas temp sensor functional problem ! is this in the water or on the hose pipe as hose water pressure may be low ? you can only run seadoos for 3min out of water on a hose pipe as the engine cooling system will overheat !
Dec 17, 2013 | Sea-Doo US 2010 GTI 130
Seadoo GTI 130 key will not make contact allowing motor to be started.
Its probably a bad dess post, try tapping on the post with a wrench or screwdriver then put the key on and see if it beeps. I have one that did that exact thing, replaced the post and it work great now
Aug 29, 2013 | Video Game Consoles & Games
Error code p1513 on seadoo 2008 gti
Had P1513 error code in Seadoo RXT 2005, means compass out of range, but this PWC has no compass. Read about the error resulting from bad fuel pump, that has no specific error code. After a while it developed fuel pump problems, changed it and the error is gone.
Aug 20, 2011 | Washing Machines
Rear bumper replacement
  Remove the tail lamps,remove the plastic retainers from the wheel well area. Remove the retainers below the tailgate opening and below the bumper. Lift up on the sides of the bumper to disengage the sides of the bumper. Pull it back a little and disconnect the connector for the park aid sensors if equipped. Pull back and it is off.
Oct 19, 2008 | 2003 Mercury Mountaineer
Samsung 2008 M600 Unlocked Watch and Mobile Phone Logo
119 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
