Question about Maytag M6Q10F2A Air Conditioner
Reading the wrong tempeature
Instead of the the air conditioner displaying that is at 60 or 65 degrees it states 19 20 21 etc etc. why is this?
  • 6,674 Answers
Centigrade (celcius) metric temperature .
19C = 66F, 20C = 68F 21C= 70F approx.
25C= 77F, 30C = 86F. There should be a setting to change that to Fahrenheit.
Posted on Jul 18, 2009
Help I tried to lower the temp for the air conditioner and now it won't turn off because it's set at 20.5. How do i reset it to 68?
I believe it is set to show Centigrade at the moment. 20.5 deg C is actually 68.9 deg F. So no worries as to the temp being wrong.
Now if you are asking how to set the display to Fahrenheit degrees instead, we will need to know the make and model.
Jun 24, 2016 | Heating & Cooling
Why does my air conditioner not run cold enough
A common misconception people have is that an air conditioner will blow cold air at whatever setting it is on. The truth is that all air conditioners can only be around 8 to 10 degrees cooler than the air passing through the air conditioner. So if you have say 30 degree air coming into the A/C you will only get 20 to 22 degree air out. If you can measure the temperature of the air entering and compare it to the air leaving the A/C to see what the difference is. If it is as stated then the chances are it is too small for the area if it cannot cool satisfactorily. If the temperature difference is not somewhere close to 8 to 10 degrees then the A/C has a problem, generally gas charge but could be other factors
Sep 06, 2014 | Heating & Cooling
On the FAH125p2T the display is reading in celsius instead of fahrenheit
Good Afternoon Friend,
I understand you are trying to change the display from Celsius to Fahrenheit. To convert from one to the other and back, press and hold the " TEMP/TIMER" Up arrow and Down arrow buttons together for 3 seconds. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire Heating & Cooling
My Dometic thermostat reads -05 degrees on zone 1 for the inside temp.It is at least 80 degrees inside. When it reads -05 it won't let the AC kick on. Any ideas?
Instant thought- bad bateries in the stat! Second thought, bad Stat- sometimes they have intermitant problems, and being soldered PC boards with chips, relays, diodes, resistors, etc. they are not fixable nor tracable on intermitant problems, simply toss it & replace with a new one. The -05 leads me to believe the internal Thermister (electronic temperature sensor) is causing your problem, it sends the chip resitance values based on the temperature it's sensing- if it sends the wrong resistance value to the chip, the chip thinks the temp is different than it really is. Make sense? Hope this helps!
Mar 23, 2013 | Dometic Rooftop RV Air Conditioner
How to change the temp in a frigidaire galaxy refrigerator
Units will vary give or take a few degrees from the control panel display. Keep in mind once you change the temperature it will take up to 10-12 hours to stabilize and reach that temperature. If the unit is not cool, even at the bottom of the refrigeration portion (where the coolest air will be found) then contact a professional to diagnose the control pane and board.
Dec 29, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
LG portable a/c model LP1010SNR and after running for about 15 mins it reads E4
salaams......the unit will stop and display E4, when coil sensor reads temp less or equal to 2 degree centigrade.so deforst it. orrrrr when the coil temperature greater or equal to 8 degree centigrade.its from manual.
Sep 13, 2011 | LG LP0910WNR Air Conditioner
The thermostate now reads 112 degrees and will not go below 97 this causes the cooling unit to stay on at all times even though the true room temp is 71 degrees. What is wrong with this thing? It appears...
Hello,Locate and move the thremostat sensor(bulb) to a different location as it is near something on the unit that is 112*f.It needs to sample return/intake air temp.
Sep 18, 2010 | Amcor Portable Air Conditioner...
Temperture bulb
A temp bulb will is only accurate to plus or minus 10 degrees sometimes as much a 20 degrees the ideal place for the bulb is in the intake air flow the bulb comes with a line that is long enough for this application
Oct 07, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
The numbers it is showing for the temp.
It is showing degrees Celsius instead of Fahrenheit. Push both the up and down temp buttons at the same time to toggle between C and F.
Jun 02, 2008 | Fedders AEY08F2FCOM Wall/Window Air...
Maytag M6Q10F2A Air Conditioner Logo
248 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
