Drum isn't turning but the drive belt is ok. taking in water and draining water fine.
The coupling on the motor ia broke you have to take the front off the washer and take the pump off there are clips you have to take off pull the motor out and the rubber coupling is right you will have to buy another coupling they cost about $10.00 then you put it back together. Tommy
Posted on Jul 25, 2009
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
The drum isn't moving....
possible drive belt is broken if so it should be fairly inexpensive to get it replaced
Oct 02, 2012 | Hotpoint Washing Machines
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
The drum does not turn.
there are two potential problems. firstis te belt to the drum drive pully from th moter. this is the easiest. take off the back panel an seeif the belt is intact. if so run through a cycle and see if the motor spins or triesto spin. if not this is most likely thesuspect. one plug three screws and about100 dollarsfixes te motor. hope this helps.
Dec 18, 2009 | Kenmore 44102 Front Load Washer
Indesit wd1030 washing machine drum not working
Your drive belt may be damaged and needs replacing
Nov 06, 2009 | Washing Machines
Maytag MAH6700AWW Humming Sound
Can you see water in the drum ?,No water = no action Check water supply
If there is water in the drum does it drain out at some point.
Sequence = Fill, Agitate, Heat, Wash, Drain, Spin etc.
If it fills then it may be a belt has snapped and the drum cannot turn , need to take the covers off to look.
Remove power before taking covers off !!!!
If the belt is OK then it may be the heater which has gone open circuit, try a cold wash or a rinse cycle to test that.
May 23, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Water drains but won't spin
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
May 20, 2009 | Fisher Washing Machines
Washing Machines Logo
Top Washing Machines Experts
