Question about Garden
My ryobi weed eter suts off when i give it gas
I have a ryobi weed eter it has worked great for the past year. this year when i started it it will idle but shuts down when i give it gas.. I have completly broke it down and cleaned it with carb cleaner, bought new spark plug. I pulled the fuel filter out to see if it was clogged, did not put it back in. did not see any cracks in fuel line. also I cannot kill it when push the kill button. I have pulled the muffler off and it was clean air flows through very easly any suggestion would be great
model ryobi ry30020a
  • 41 Answers
SOURCE: engine stalls when giving gas
Make sure you have the carb. fuel line on the correct side of carb. Not on primer bulb side.
Posted on May 15, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
Blackberry_U
  • 223 Answers
SOURCE: Weed Eater GTI 15 won't run???
Check the gas lines, one might be bad...
Posted on Jun 01, 2009
SOURCE: RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Posted on Aug 02, 2009
moretons
  • 155 Answers
SOURCE: 2-cycle toro weed wacker does not start
Sounds like the flywheel has come loose and sheered off the key which locates it on the crankshaft without this the timing will be out ,
Posted on Aug 04, 2009
Customer satisfaction I have purchased 2 Ryobie
Take better care of your equipment and it will last longer
Aug 01, 2013 | Ryobi Garden
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
Ryobi blower will not start unless primed by
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Sep 28, 2009 | Ryobi Backpack Blower 25.4cc
My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a ryobi weedeater model 764r. how do i reset the mixture screws.it won't start.
I replaced the gas line hose and the spark plug on a 2075r ryobi proffesional weed eater. Now it will not start. Thank you
Jun 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Have a Ryobi CS30 Weedeater, will not start, it is about a year old, did not see a spark, just bought new plug.
If you still don't have a spark with the new plug, then you may have a kill switch wire grounding the motor, keeping it from starting. If it's not that, then you have a bad ignition module (coil).
Jim
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi weed trimmer is easy to start and idles great. It will not rev up high enough to cut. Only likes lower rpm. Sounds like it is only giving up about 1/2 of the rpm's as when it was new. Changed the...
If you have a spark arrester fitted, it will be blocked with carbon preventing the exhaust gases leaving. It will be behind a plate bolted to the exhaust silencer/muffler. Scrape the carbon off the wire mesh carefully, until you can see through the mesh again.
Apr 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
