Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Foxconn 945G7MD will not start every tim...
By shortcircuit on Nov 18, 2007
Some time the computer start, and other time it will not start at all. After taking the CPU out and back again, some time start. I have changed every thing in the box and even started the board out side the box. It sems to me that the there is a contact problem between the CPU ( Intel P4 2.3 Ghz 775 Sockt). Has any one had the same problems? Thanks
Comments:
Nov 19, 2007
- I get the same problem even when the board is out of the case and I did reset the BIOS using the onboard jumper. Today I called the tech. support of the supplier and they think it is related to the BIOS can not see the CPU. A BIOS update may resolve the problem. I still think it is a contact problem because if I put some prusser on the back of the board around the CPU, some time it comes on. I have never been happy with the new 775 socket but I will do what they say and keep you informed.
Thanks
Same Problem
Dec 26, 2007
-   I have the same problem (K8N DL). pm pc 2xcpu 4x1gig 3xhdd
I removed every thing left 1 cpu and a ram, then it started. turned off, left it about 20sec turned on nothing happened. Removed all again + com battery reset, install 1 cpu and 1x ram, nothing. installed all parts, left it for 48 hours, turned on the power switch. LED light flicker for a while then power comes on and cuts off immediately. after few seconds try it again system comes up and everything is fine. only problem is that if I shut it down same thing will happen. I do not know why. but think there is a short somewhere
but then again if there is one the system shoud shut down or crash. but that doesnt happen.
any halp please-   1shadow1
Best Solution
posted on Apr 11, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hi. I did update the BIOS but it did not solve the problem. I got in touch with Foxconn Tech Support and I was asked to change the board, then all problems solved. It was a faulty motherboard.
Thanks to all.
Emad
Solution #2
posted on Nov 19, 2007
Somewhat Helpful)
Eblackadder
Rank: Guru
Rating: 85%, 131 votes
Does the unit start with the board removed from the case? If so I would say you have a grounding issue. Make sure you have the little insulated washers on all the screws holding the M/board in the computer. Other than that try resetting the bios using the onboard jumper, usually jumper J4 or JP4
Comments:
Nov 20, 2007
- Looks like time for a replacement motherboard.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
update bios resolve this problem
try it and replay
eng emad naseeif "egypt"
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS... (More)
Answer
compaq presario mother board, what should I replace it with
Answer
motherboard has blown the chipset. what is the replacement part number and how much ?
Answer
I need a new cooling fan/heatsink for a Foxconn N15235 motherboard. Which model of fan/heatsink... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in Orlando, FL
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
