Question about Electrical Supplies
Generator willnot fire on a 5hp briggs&stratton engine recoil start.
Try taking the spark plug out. If it hasn't been replaced in a year, replace it with a new one. I had the same problem and the ceramic part of the spark plug had a fine crack in it. Also, it is possible you have a coil problem, which may take replacement.
Posted on Jul 25, 2009
  • Clay Craig
    Clay Craig Aug 24, 2012
    I just put new spark plug in it.
How much oil does a briggs & stratton 5HP engine need
Manuals You can download the manual for your particular engine from here.
Oct 22, 2016 | Briggs & Stratton Measuring Tools &...
5hp Briggs engine on craftsman snow blower won't stay running
Remove the nut that holds the float bowl on and clean the hole on the side and the hole that goes down the center of the bolt.
Jan 05, 2014 | Briggs & Stratton Snowblower Snow Blower...
Briggs & stratton 5hp motor will not start
Check the flywheel key, it may have sheared. If the key shears it will throw timing way off. This would cause a backfire or "pop". Start there and let me know, Daniel
Oct 22, 2012 | Garden
Cleaned carb installed new gaskets jets were clean dont know what the idle or mixture screws are set at to get it started (recoil start) turned them to 1and a 1/2 no luck
i usually set the idle screws to 3 turn then adjust to fit. it hasnt faid me yet with the three turns. turn all the way in and when it stops turn out three complete turns of tool on hi side and low.
Jul 10, 2011 | Briggs & Stratton Briggs and Stratton...
Just bought a generator 5000/6250 style but my husband can't pull the recoil handle. i think it's stuck so we can't test the generator. the unit was shipped from california to the philippines. pls advice...
Try removing the spark plug and rotating the engine by hand.
It could be just a little corroded from shipment over the ocean.
But once you have it loosened up and the oil circulated, it should start much easier.
Make sure it has oil in it, because sometimes they drain the oil before shipping.
You could also have someone else try the starter rope. A new engine can be hard to start.
Oct 04, 2010 | Briggs & Stratton Briggs and Stratton...
I have a 5550 Watts Briggs & Stratton that only ran since purchase for 2 hours tops The pull starter locked up when I tried to start engine.
unscrew the four bolts holding it on and chek the rope has not become tangled dont unscrew the centre bolt as the recoil spring will suddenly shoot out everywhere
Mar 20, 2010 | Briggs & Stratton Power Products 5,550...
Recoil starter spring has unwound Briggs & Stratton 4 HP mower motor
you can buy the whole recoil + pull cord ready to install ,or have a small engine shop rewind it if you cant. some times the tab that held it breaks and you have to replace it.
Mar 06, 2010 | Briggs & Stratton Power Products 5,550...
5hp Briggs & Stratton, idles great, but won't throttle up.
Hello, I have a older B.S. replacement engine for my sears riding mower. I have got it all installed but my gas tank is in the rear under the seat. The engine doesnt come with a fuel pump. I bought a vacum pump but does'nt have a port. I under stand the in and out on the pump. I took the engine cover off looking for a vacum port and cannot find one. I also looked all around the intake not one there. The only thing is the air breather. Can someone assit me in hooking this up to make it work. Thanks so much
Aug 27, 2009 | Boating
5hp Briggs & Stratton lawnmower starts but stop running?
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
May 17, 2009 | Craftsman 16" High Garden Tractor Snow and...
Electrical Supplies Logo
103 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
