Question about Toshiba 32AF43 32" TV
No image only a dotted line in center of screen that also dissapears after 30 seconds.
    Sergeant:
    Champion:
  • 375 Answers
The vertical scanning had stopped .requires a vertical ic and caps,dont leave on to long or burn will happen to the screen.
Posted on Mar 29, 2008
Msi L1350d screen has tiny horizontal lines
If it works fine when you connect to your tv then you've probably got a loose cable on the screen. You'll have to strip it to check.
Mar 29, 2014 | MSI L1350D-1672US Netbook
Vertical black bar on my LG 47" LCD shifting the image to the right
Two possibilities are there. The first one is, with loose LVDS cable, that connects the T'Con board to display panel. The second is the fault with its main digital processor board.
May 21, 2013 | LG 47LC7DF 47 in. LCD HDTV
Hi, Expert: I have a 52" Sony LCD TV (
Hello
If I send you its schematic diagram and give you instructions, can you follow me?
Oct 18, 2011 | Televison & Video
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
I have dots all over my screen. How can I remove the dots?
Try unplugging the TV and leaving it unplugged for 30 minutes..
Then try plugging it back in.. If the dots dont dissapear.
Try shutting it off.. and removing all input cords.. Are the dots still there with no input going into it..?
If not, then the issue is with one of your cords or input devices ( cable box, dvd player , etc)
If the dots are there without anything plugged in. Its an issue with the Tv itself, and will need to be serviced
Aug 03, 2010 | Sanyo Televison & Video
What is subfield ? panasonic says subfiels what is subfield ?
Does this help
A standard video signal is actually a series of still images, flashed on screen so quickly that we believe we are watching a moving image. The typical frame rate used in North America is 60 frames per second (60Hz) meaning that a TV would display 60 individual still images every second. Sub-field drive is the method used to flash the individual image elements (dots) on a plasma panel. For each frame displayed on the TV the Sub-field drive flashes the dots 8 times or more, meaning that the dots are flashing 480 times per second (480Hz) or more. (Example: 60 frames per second x 8 sub-fields = 480 flashes per second). subfielddrive_en.jpg
Jul 10, 2009 | Panasonic Televison & Video
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Red dots and lines on mobile touch screen
You can try a hard reset on your phone by removing the battery for 30 min and then power it on if lines still exists then it is display hardware problem you may need to change display in the phone ...........
Good luck...
Jan 07, 2009 | O2 Xda Atom
Toshiba 32 in regulat tv
Solder and / or replace vertical output IC......Verify model #
off back of set for further info............
Nov 18, 2007 | Toshiba 32AF43 32" TV
Toshiba 32AF43 32" TV Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
