Question about Dell Inspiron 1525 Laptop Midnight Blue
DVD rom not working
It shows the exclamation mark next to the drive and when I put in a disk it just doesn't work. In my computer, it doesn't show the drive either. Don't tell me the stuff about uninstalling and reinstalling. I tried that many times and it didn't work. Just help me
  • logepoge1 Jul 18, 2009
    i want real help no links and this **** is roughhard to look th
DVD will not read any type of disk.
If there is an EXCLAMATION Mark for the DVD, the device could just be failing on you.
Mar 05, 2014 | OEM Systems Dell Xps 15 L502x L501x Blu...
My cd-rom location do not show up on my Dell Dimension 8250 computer devices. Why
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps.
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
Dvd rom not working and can not be enable by BIOS also not showing in
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Sep 20, 2012 | Computers & Internet
My dvd rom is not showing in My Computer
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Aug 18, 2012 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Cd stuck in emachine and there's no pin hole
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope it helps
Jun 15, 2012 | E-Machines emachines (emachinees) CD-ROM...
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
Hi my computer doesn't see dvd/cd drives .When i pull it up in device manager it shows drives but they have a yellow exclamation point in front of drives what can i do . thanks hotrize
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 18, 2011 | Microsoft Windows XP Professional
Slimtype BD E DS4E1S....blue ray Which is not working properly d drives shows om computer but when i put cd or dvd it wont show the disk and whenever shows the disk it shows blanck disk also i cant able to...
hello everyone,
i have an asus n53sv laptop. i have formatted the hard disk and installed a new win 7 ultimate 64-bit OS. after installing i have noticed that the system blu-ray disc rom is not working. in the device manager there is a yellow mark next to the DVD/CD rom drives. i have tried uninstalling it from the system several times and restarted the system to recognize the blue ray disc rom but no chance. i searched the internet for the right driver, but i haven't found one. can u help me to find the right driver for my Slimtype BD E DS4E1S ?
May 15, 2011 | Computers & Internet
My pc
Replace the drive is the only thing you can if you are sure the drive is not functioning.
Jun 11, 2008 | LG CRN 8245B (CRN-8245B) Internal 24x...
CD rom drive not working
sounds like it's gone home early. replacement will do the trick..
Mar 06, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Dell Inspiron 1525 Laptop Midnight Blue  Logo
22 people viewed this question
Alun Cox
