Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
I secured my wireless network, i put a password to it, and right after i finished, i wasn,t able to conect to internet anymore
  • 378 Answers
Reset your modem and reconnect
Posted on Jul 17, 2009
Dell vostro a860 won't connect to internet
Why not? Do you have the wireless turned on? Did you put the correct password in?
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
If you put the wrong password in, it will never connect. it will keep trying to connect but never will.
Authentication
That means you probably don't have the password or the Authentication Type set correctly.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 28, 2012 | Dell Vostro A860 Notebook
I wuold like to know please all step to put pasword in my wireless links, because pleanty hause around and get slow because every boddy is conected in my wireless, please i need to know the way to put the...
connect to your router via cat 5 cable.
open internet explorer
browse to 192.168.1.1
login is blank password is admin
click on wireless
setup your wireless ssid network name
click on wireless security
select wpa
type in a passphase for your wireless password.
May 23, 2011 | Linksys Wireless-G WRT54G Router
How do i set up my dlink to work with my new laptop.currently it is conected to my desktop computer. trying to manually add my wireless conection. Need to know my Network Name(1-32case sensitive...
Your laptop should be able to automatically find the network name and security type. (You would have set up all of this, by the way.)
You should then type in your security key/password (you should have set this up when setting up router for first time, also) and then you should be connected to the internet.
Your laptop might not have wireless capabilities, so you might have to buy a wireless network adapter.
May 19, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
How do i find the wpa key to conect my to my xbox 360 to the internet
  1. Open Network and Sharing Center by right-clicking your connection icon at the bottom-right corner of the screen.
  2. Click the link of the network you're connected to. (Should say "Wireless Network Connection 'router's name here')
  3. Then click the button "Wireless Properties"
  4. Then click the Security tab
  5. It should show your Security, and Encryption type. Also there should be your password in secret bullet form. Simply click "Show characters" and Voila! Your WEP key should be staring you in the face.
Sep 17, 2010 | Computers & Internet
Belkin 54g Wireless DSL/Cable Router (DHF5D72304): my conection says my signal strenth excellent but ...
1. Log into your Wireless Router or Access Point.
Open your web browser and type in the IP address of the Wireless
Router or Access Point. (The Router’s default is 192.168.2.1, the
Access Point’s default is 192.168.2.254.) Log into your Router by
clicking on the “Login” button in the top, right-hand corner of the
screen. You will be asked to enter your password. If you never set
a password, leave the password field blank and click “Submit”.
Click the “Wireless” tab on the left of your screen. Select
the “Encryption” or “Security” tab to get to the security
settings page.
2. Select “128-bit WEP” from the drop-down menu.
3. After selecting your WEP encryption mode, you can type in
your hex WEP key manually, or you can type in a passphrase
in the “Passphrase” field and click “Generate” to create a WEP
key from the passphrase. Click “Apply Changes” to finish. You
must now set all of your clients to match these settings. A hex
(hexadecimal) key is a combination of numbers and letters from
A—F and 0—9. For 128-bit WEP, you need to enter 26 hex keys.
For example:
C3 03 0F AF 4B B2 C3 D4 4B C3 D4 E7 E4 = 128-bit key
4. Click “Apply Changes” to finish. Encryption in the Wireless
Router is now set. Each of your computers on your wireless
network will now need to be configured with the same
security settings.
May 18, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Cant connect wireless dont know network key (password)
you can find this network key or password or wep key, inside your modem configuration page. to do this.
1.use a pc that is conected to the modem
2. goto start then run and type cmd press enter.
3. type ipconfig and press enter.
4. the defualt gateway is like 192.168.2.1 or some thing like this. enter this into internet exploere or firefox adress bar and press enter.
5 you should be inside your routers configuration pages.
6 navagate till you find the wireless security settings.
7. look for wireless wep key.
this is what you need ot enter into your printer to conect to wireless network.
Nov 30, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Connection problems with secondary computer
hi
the key code is the security code or the password that is enabled in the router,are you trying to connect to you own comcast network or to someone elses??
if you are conecting to your own comcast network then you need to log into the computer which can go online using you comcast box,once you are in that computer you need to go ahead and click on start,run in the box type in cmd and hit enter,it shud open a black box for you in this black box go ahead and check the default gateway an example of default gateway wud be like this no 192.168.1.1,make a note of the default gateway and open an internet explorer page now type the default gateway in the address box without http,it shud open the router page for you from comcast,it will tell you to put in the user name and password,the default for comcast is username is comcast and password is 1234 incase you cannot login you can contact comcast so that they can reset the password for you,once you are in this page you will see the wireless setting click on it and there you will see something wghich says wireless security or wep key or authentication key that is the key code..u can now use this key code to connect to the network....
if you are trying to conect to someone elses network thent he person who has setup the wireles comcast network will be able to give you the network key...
vedhick
Jan 21, 2009 | Dynex Wireless-G USB 2.0 Network Adapter
Sir, i cant acces irles internet conection from my room,becuse i don't know pasword
Try accessing the configuration page of your router by typing 192.168.0.1 on the address bar of your browser and log-in to the dlink.
>Configure your wireless setting on this window.
>Under setup click on wireless setting
>Then click on manual wireless ....setup
>You will have the configuration of your wireless network.
>You may use WEP or WPA for your password on your security
>For WPA with pre shared key or passphrase the minimum character for your password is 8 characters
>For WEP with pre shared key of passphrase the minimum charactere for your password is exactly 10 characters.
>Once you have save your wireless network
>Go to your laptop and connect to your wireless network before
connecting to the Internet.
Jan 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Wireless security
the WEP password is located on the label on the botom of your router. The WEP password prevents unotherize conecting to the network. If some one for example like your naber see your network and conects to but put in the wrong WEP they will not be able to use your internet.
Jan 04, 2009 | Dell TrueMobile 2300 Wireless Broadband...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
119 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
