Question about InFocus ScreenPlay 4805 Multimedia Projector
Light went out
I was using 4805 and the bulb went out. I replaced the bulb but it will not light. The green light is flashing.
  • 2,237 Answers
Then it may not be the lamp, but make sure you have the right one (sp-lamp-021). also check to see if the colorwheel is moving. turn the projector on and listen for a high-pitched whir. if you don't hear one, the colorwheel needs replacing. and the lamp won't light without the colorwheel spinning.
Posted on Aug 17, 2009
Testimonial: "Thanks for the input. I ended up sending the unit in for repair. "
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
No picture
the projectotr circle is the colorwheel and it has to be replaced. as far as having no picture, is the led on top flashing red or green ? If flashing red how many times ?
Jun 12, 2010 | InFocus ScreenPlay 4805 Multimedia...
No picture coming out
where is the red flashing light comming from is there a image or text saying what it means?
but to be hinest i belive that the bulb has finished and died
May 13, 2010 | InFocus ScreenPlay 4805 Multimedia...
Infocus 4805 Lamp will not ignite after new bulb and reset.
it there is no high-pitched squeal when it starts up, the colorwheel needs replacing. the lamp won't light without it. the part is under $50, but installation is quite involved.
Apr 16, 2009 | InFocus ScreenPlay 4805 Multimedia...
In the manual there is a chart which will indicate the nature of the failure depending on the number of times the red led flashes before a pause.
Most common is the projector's lamp timer has exceeded the operational lamp time limit.
While the projector's red led is flashing, press the volume up and down buttons on the projector simultaneously and hold them both in for 10 seconds.
This will reset the lamp inhibit protocol.
However if the lamp has thousands of hours of use you need to replace it before it actually fails.
Feb 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
I turn on the 4805,green led blinks & bulb does not come on?
After a few minuets does the green blinking light turn to a red blinking light?
If so the problem is the lamp did not strike.Either the lamp has failed (most likely) or there is a problem with the power supply (less likely)
Feb 12, 2009 | InFocus ScreenPlay 4805 Multimedia...
4805 w/less than 300-400 hours has blinking red light
Yikes. I bet the bearing is bad in the fan and/or the fan is rubbing up against something. It might be an fix.
Jul 16, 2008 | InFocus ScreenPlay 4805 Multimedia...
Projector problem
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
Jun 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
164 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
