Question about Alpine CDA-9807 CD Player
Instaling alpine car/cd stereo cda 9807
Installed stereo into toyota camry 1988 base model, double checked wiring, and fuses, getting no power at all.....grrrrrrr. Please there a fuse inside the unit that could be blown???
How do i install my alpine cda 9884 ...on a 92 caddi
Posted on Nov 18, 2008
Its probably your wiring harness that came with the stereo. Which can cause many more problems. alpine changed their wiring harness around that time. But they used the same plug, just wired different. So now there are crossed wires, but the plug fits, causing the amp chip to fry. maybe even further than the amp chip. an amp chip replacement runs about 80$ at a repair shop. if its just that.
Posted on Apr 12, 2008
Alpine cda 9807 in yukon xl
hi david, check out the connection of the yellow and red wires on the back plug. yellow must be connected to a direct battery positive line(continuous positive), the red must be connected to a live wire from the ignition switch OR from a point that is +12v live once the car is started(switched positive). also make sure that that the ground connection is a direct good connection to the body of the vehicle!! make sure that the remote wire(blue) is insulated if you not using an automatic aerial or external amplfier. good luck.cheers.
Sep 08, 2013 | Alpine CDA-9807 CD Player
Where can i get the code to use this as i have just installed it in my new car?
there is no code for that radio. what exactly is the problem with it? if it is not turning on, make sure you are getting power to both the red and yellow wires. red is switched (ignition) and yellow is constant.
Jan 16, 2011 | Alpine CDA-9807 CD Player
I need wiring color codes for a ford focus factory stereo
I assume you want to know which color wires are what from the factory stereo to hook up the Alpine which you have the wire colors for?If you call a Ford dealer,they normally will provide the information for free.I googled a couple of sites but the minimum they want is $14.Good luck! Greg
Sep 27, 2010 | Alpine CDA-9807 CD Player
Hello! In clock priority mode...Press and hold the Disp/Title button for 3 seconds, The time indicator will blink...Turn the Rotary/Encoder to adjust the hour...When hour is set, turn the Rotary/Encoder to adjust the minutes...Time is set for 5 seconds after the minute...
Feb 20, 2010 | Alpine CDA-9807 CD Player
Alpine cda-9813 no power
You check the radio fuse in the fuse panel?The wire connections are right? Check the Owners Manual for other details or troubleshooting: ALPINE CDA-9813
Hope helps.
Jan 29, 2010 | Alpine CDA-9813 CD Player
I've got a 1988 Dodge Ram and I know nothing about Car Stereos
go down to a electronics shop (future shop or best buy) and they will have a connector that will fit the original plug. Some splicing will be required but its all color coded with the deck
hope this helps
Nov 15, 2009 | Alpine CDA-7840
Alpine cda-9807 no voice when cd plays.
Try to set the cd function to settings! or menu, maybe you have not fair settings in your unit!
Sep 23, 2008 | Alpine CDA-9807 CD Player
I dont have a colour code for the wiring
Red is ignition
Yellow is constant hot
Black is ground
Gray wires are front right
White wires are front left
Green wires are rear right
Purple wires are rear left
Blue is power Ant if equipped
Orange is ilumm
Make sure you use the proper wiring harness for your vechile.
Hope this helps
Jul 06, 2008 | Alpine CDA-9807 CD Player
A.M. stations
What type of vehicle is it in? Some manufacturers, such as Toyota, use separate antenna plugs for AM and FM that cannot be plugged into an aftermarket unit at the same time.
Sep 18, 2007 | Alpine CDA-9807 CD Player
Alpine CDA-9807 CD Player Logo
373 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
