Question about AEG Lavamat 72640 Front Load Washer
How do I open a AEG Lavamat 805 front load washer
Something (probably a plastic obeject,comb, ...) has left the drum and found its way into the interior part of the machine. Now giving all types of sounds when washing/spinning. Doen't seem to do any seroius harm, but would like to remove it. Haven't opened the machine yet, but how do I in the aesiest way get open the interir parts of the washer?
Regards Halvor
  • Halvor Nov 19, 2007
    Correction: The model is Lavamat 508...
    New Friend:
  • 32 Answers
Remove the whole front panel
Posted on Dec 15, 2017
  • 1463 Answers
SOURCE: AEG Lavamat 1000
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
Posted on Mar 03, 2008
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
  • 3463 Answers
SOURCE: AEG OKO-Lavamat 1271 VI Turbo
Sounds like the main drum bearings have failed.
At this age , I don't think this is an economical repair to undertake.
Better to replace with a new one.
Posted on Dec 13, 2008
  • 326 Answers
SOURCE: I need cogs for my aeg lavamat where i CAN GET IT?
you can get it at
Posted on May 06, 2009
SOURCE: I have an AEG Lavamat 16820 washer dryer and the
The lock is rubbish on this machine but as a temporary measure you can feed a string down behind the door lock from the top and out the bottom. Then yank it to the left to open the lock. It will take a few tries but you get the hang of it!
We got sick of this so ordered a new lock off the net. I basically had to break the old mechanism to fit the new one because the door layers were so strongly glued together. Now fitted, the lock works perfectly but the machine thinks the door's open the whole time! Next step is either new door or new machine. Great.
Posted on May 12, 2009
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 72 620 What does error code C9?
c9 means the electronics is not detecting any drum movement. check the carbon brushes in the motor this is usual culprit.
Aug 29, 2010 | AEG Lavamat 72640 Front Load Washer
Hi, I bought a new frontdoorgrip. Partnumber 0012932; for the Lavamat L16810. When mounting the screws I found out that they are too thin: I can push them easily into the holes. Do I need nuts behind...
No nuts. The screws fit into the plastic electric door mechanism which, after you took the screws out, will be hanging iside the machine. Either take the lid off to access or, easier but a bit fiddly, is to feel for it (with your left hand) through the rubber drum seal. With a bit of manipulation you will see the screw holes and door catch appear; line them up and replace screws and plastic facia.
I did the same thing and learned not to unscrew anything without knowing what it's there for!!!
Aug 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
I have a aeg lavamat turbo washing machine .when start it the water does not got to the drum ane water never stops simply running
You have a syphon - the waste pipe is probably too low and the end sits in water in the drain, meaning the water runs through the machine and out the waste.
Jun 30, 2010 | AEG Lavamat 12710 Front Load Washer /...
Reply to aeg lavamat w1450
Further to your prob with washer, I would be inclined to think that there is a foreign object in the drum.Hopefully it will find it's way in to the pump filter.I don't think it will cause a problem
Merry xmas.
Dec 14, 2008 | AEG Lavamat W1450 Front Load Washer
Sounds like the main drum bearings have gone, if you hold the the drum and can feel up and movement or it sounds noisy or rough when you turn it by hand then it is definately bearings gone.
Unless you know what you are doing ,I would not recommend a D.I.Y. repair.
AEG lavamat 6955 showing F9 on display panel
unplong machine and restart it .eamonn eire thank you
Jan 26, 2008 | AEG Lavamat 88840 Front Load Washer
How to re-fit front rubber seal on Lavamat
The seal is mounted to the outertub with a big spring, an on the frint with a plastic ring. Not very easy.
Jan 20, 2008 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 72640
Probably the motor is broken. Or the tachometer is loose from the motor.
Dec 26, 2007 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 72640 Front Load Washer Logo
101 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
