Question about Garden
My hedge trimmer attachment for my troy bilt edger continues to disengage while i am using it. this jst started to happen after i tried to cut a limb that was too thick
  • 49 Answers
SOURCE: Troy-Bilt Trimmer TB425CS
Sound like the clutch is going out or already is bad. There should be a cone shape cover that attaches the engine to the handle. Usually with 4 screws. Take those screws out and seperate the housing. There is a small centrifugal clutch, which is probably bad.
Posted on Jan 30, 2009
  • 7 Answers
SOURCE: troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Posted on Nov 10, 2009
rycgl
  • 1545 Answers
SOURCE: I own a Troy-Bilt 425cs
The power edger attatchment may have a slightly different coupling size on it than the other attatchments. Also, do a good inspection of the power head unit's coupling at the EZ LINK connector. Maybe the head unit connector is getting hot over time, due to a lack of lube, and expanding internally, causing slippage in the connection to the edger attatchment. Inspect all that you can.
Posted on Sep 11, 2011
emissionwiz
  • 78267 Answers
SOURCE: Troy Bilt edger dies as soon as its under a load--like edging my driveway.
The only real explanation for this is that a tiny piece of dirt has gotten into one of the tiny fuel jets. Remove the carb and blow it out thoroughly with compressed air.
Posted on Nov 23, 2011
  • 192 Answers
SOURCE: how do you service the edger on a Troy-Bilt Trimmer TB425CS
go to there web site.
Posted on Aug 12, 2012
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Fixing straight shaft attachment on Troy-Bilt string trimmer
Here is a link to sears parts direct. You can see prices for all parts and make a decision from that.
TROYBILT Trimmer Boom and trimmer Parts Model TB75SS
Aug 16, 2014 | Troy-Bilt Tb75ss
I own a Troy-Bilt 425cs string trimmer with multiple add-on attachments. The unit works fine for string trimming, brush cutting, and cultivating. However, it will not properly power my edger attachment. ...
Sep 11, 2011 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
String trimmer cutting attachment doesn't turn fast enough
Take the shaft off at the motor,see if any thing is worn there.Also,take head off of end of weed eater,check for grass or any build up in there.
Aug 29, 2009 | Troy Bilt Tb70ss Gas Trimmer
Jan 20, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
