Smoke out the exhaust with a motor oil smell
Blue smoke is oil , check oil level on dipstick if vehicle was just over filled you might get lucky and that could be the problem. If not the piston rings are not clear the oil off and it's burning in the chamber
Did you overfill your car with oil? Did you check the dipstick? Is that why you are thinking there's too much oil? What color is the smoke coming out of the exhaust? If it's white, you could have an issue with the piston rings, as the oil burns it's leaking out through the cylinder piston rings if they are worn down.
