Question about John Deere 22 In. Rear Tire Chains
Where is the 20amp fuse box on my stx38? - John Deere 22 In. Rear Tire Chains
2013 VW Jetta LS, fuse for cigarette lighter is not working. can someone please tell me the location of this 20amp fuse?
fuse location number 42 (20amp)
in the fuse box on the right hand side of the dashboard
Aug 11, 2016 | 2013 Volkswagen Jetta
Can you tell were the fuse for the center console power outlet?
Battery junction box / under hood fuse box .
F17 20amp - early production model
F22 20amp - late production model
Smart junction box under dash panel left side
F15 20amp.
Jun 11, 2015 | 2007 Lincoln MKZ
What causes both cooling fans to not run?
Hi Naomi , there is a lot involved in the control of the cooling fans on your vehicle ! There are three fuse's , three relays an a fan control unit !
1. radiator fan main relay , located in underhood relay box A
2.condenser fan relay , located in underhood relay box A
3.radiator fan relay , located in underhood relay box C
4.Cooling fan fuse # 47 20amp. underhood fuse / relay box
5.condenser fan fuse # 50 20amp in underhood fuse / relay box.
Any one of these could cause them to not work, rather then just replacing parts an wasting money you should take it to the repair shop !
Apr 06, 2015 | 1997 Acura RL
What could cause both nospark and fuel together at once,one conponet responsible for both failures
Hi Bill , what engine does yours have , 4.3 , 5.0 , 5.7 ,6.5 L ? Check fuse's ECM 1 20amp an ENG 1 20amp in the under hood fuse relay box !
Mar 27, 2015 | 2000 Chevrolet Express Cargo
I pluged in a small car vac in the power outlet , after ten minutes it blew. Owners manual dosen't say there is a fuse for it.
There should be a cig lighter-accessory relay in the box near the battery. It is powered by a 9amp fuse and a 20amp fuse. The 20amp fuse is in the same box with the relay.
These fuses and relay power the front and rear outlets.
Dec 21, 2012 | 1999 Dodge Caravan
Fused rear 12v socket c4 picasso
FUSE BOX HIDDEN IN CARGO AREA
May 23, 2012 | Cars & Trucks
My dome light in my 86 accord won't work and
Check your fuse box, it might be that simple. It should be located in the engine compartment (under the hood). When you find the fuse box, there should be a map of each fuse there and what each fuse powers. If one of the fuses is burned out, you should be able to replace it (make sure you use the same rated fuse -- a 20Amp for a 20Amp, or a 5Amp for a 5Amp -- usually they are color coded) and that should solve the problem. Japanese cars USUALLY have all of the fuses under the hood, but there is a chance that there might be a fuse box (or second fuse box) in the glove compartment, or under the dashboard.
If the fuse is not the problem, there might be a short circuit between the fuse box and the broken components. Bad wiring is much less likely, and much harder to fix, so if it is worth it for you to get it fixed, I recommend visiting a professional mechanic. If you don't want to invest that much money to repairing the issue, but need the Cig lighter to power a cell phone charger or GPS, you can run a bypass wire from the fuse box straight to the cig lighter. This will give you back your lighter, but will not solve the problem, which could indicate something more important, so it would be good to have a professional mechanic check it out when you have the time and money.
May 23, 2011 | 1986 Honda Accord
Fuse box diagram
The fuse should be a 20amp and it should be in the inside fuse box from the fuse puller side it should be the 6th 20amp fuse down...counting from the fuse puller. Hope this helps. Good luck!
Apr 24, 2010 | 1994 Honda Accord
Need a diagram of the fuse box for a 1994 volk
Heres a picture of fusebox,and listed is the fuse locations,1) 10amp left low beam light
2)10amp rt low beam light
3)10 amp instrument& license plate light
4)15 amp, rear wiper
5)15amp frt washers and wipers
6)20amp A/C fresh air fan.
7)10amp rt tail & side marker lights
8)10amp left tail & side marker lights
9)20amp rear defroster &heated mirrors
10)15amp fog lamps.
11)10amp left high beam
12)10amp rt high beam
13)10amp horn, rad fan run on
14)15amp backup lights (m/t),power mirrors,heated seats,heated washer jets,cruise control (m/t)
15)10amp engine electronics,coolant pump run on(v6)
16)hazard signals,glove box lite,shift lite
17)10amp turn signals
18)20amp fuel pump, oxygen sensor
19)30amp a/c, rad cooling fan.
20)10amp brake lights,cruise control.
21)15amp dome light,cigar lighter,locking system,multifuntion indicator,clock,vanity mirror.a94b062.gif
Mar 10, 2010 | 2003 Volkswagen Passat
Where is the fuse for the right door window? Honda Element 2003
Fuse 22 (20amp) in the interior fuse box (just to the left of the steering column, down low, behind the access door) is the front RIGHT power window. Fuse 23 (20amp) is the front LEFT power window (I think that's the one you want).
Hope this helps you.
Nov 01, 2009 | 2003 Honda Element
John Deere 22 In. Rear Tire Chains Logo
375 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
