Question about Amana 3.2 cu. ft. Top-Load Washer
My front loading washer walks during use. Is
My front loading washer walks during use. Is there a way to balance it?
    Sergeant:
    Novelist:
  • 197 Answers
Ther feet to the front of the washer are adjustable. You need either a spanner or a pair of pliers to adjust them. Get a spirit level and check which way the washer needs adjusting to make it level. Adjust the feet accordingly
Posted on Jul 17, 2009
My whirlpool Duet 9750 takes a long time to spin out and has a difficult time trying to balance
I owned a Whirlpool Duet and had spin/balance problems when I washed heavy and light items together. During a deep freeze my drain hose froze. Did everything I could think of until I ran hot water through washer. It took awhile to thaw. If your floor is weak, you will have a lot of vibration and walking. Hope this helps.
Dec 28, 2011 | Whirlpool LSW9750 Front Load Washer
Washer balancing load, during spin cycle wasker shakes and walks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Balance, washer shakes and walks across floor
Have you checked to make sure the supports are OK? Is your washer making loud noises during spinning? If so, the basket drive may be broke.
Washing machine balance is off since we moved it.
There are tension springs attached to the tub. They are for the balancing upon spinning. Check and see if one came loose
May 12, 2010 | Maytag EPIC MFW9700S Front Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Timing is off
timing is not the probelm off balance load or washer not solid on floor is...front load washer try to balance load as much as possible before full speed spin the 10 min is only and est ..additional time will will be taken trying to balance load and no ge won't do anything about the walking best try getting machine as solid as possible if on pedistal good luck..lower bottom as close to floor as possible both rear legs all the way up adj front legs for solid setting try rocking washer and adj legs till solid..also weak floor?
Jul 08, 2008 | GE WSXH208A Front Load Washer
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Moving
Don't know if you've done it, but put a level on the machine itself and make sure it is level. Adjust it front, back and side to side. This may cure your "walking problem".
Jan 28, 2008 | LG WM-2277HW Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
166 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
